Old 05-27-2013, 08:29 PM   #1
rideblue00
rideblue00's Avatar
Alum grill cleaning
So i havent contributed much here and i came across something i think worked good and wanted to share. I recently bought a plating kit to redo some bolts. It came with something called Autosol Metal polish. I tried it on a spare alum bezel i had and it came out good. So i decided to go ahead and do my grill and the bezels. My grill wasn't too bad to start with and this stuff made it look pretty good. It didnt come with any instructions and all i did was put some on a lint free rag and just polish it. Not hard at all took like 2 hours. My grill is a driver quality anyhow and now it looks a little better. Heres a few pics. I used gloves to keep my fingers from soaking up the polish. It has a smell of maybe mineral spirits. It dries like wax a little and then i used a clean rag to wipe any leftover residue. Simichrome polish might be similar, not sure i dont have any of that stuff. Check it out.
rideblue00 is offline   Reply With Quote
Old 05-27-2013, 10:17 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Alum grill cleaning
Wow, very nice!!
The biggest problem with the aluminum grills is that the clear anodizing wears out and the grill takes on a dull, cloudy look. That polish really did a nice job. I'm going to have to get some of that and try it on my grill.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-27-2013, 10:21 PM   #3
rideblue00
rideblue00's Avatar
My pics dont do it enough justice. But it came out ok.
Old 05-27-2013, 10:31 PM   #4
CRGRS 66
CRGRS 66's Avatar
once you get a polish on, can you have it re-anodized, or do you need to remove the old anodizing first? Does the polishing you are doing remove the anodizing?
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-27-2013, 10:56 PM   #5
rideblue00
rideblue00's Avatar
Im not totally sure on that. I assume the anodize needs to be removed then polished and then re-anodized. Someone with more info should be able to say more definitively.
Old 05-27-2013, 11:40 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
Someone on here was using oven cleaner to remove the anodizing, it only took 5 minutes as I remember, then rinse well and polish...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-27-2013, 11:55 PM   #7
1963c-10
1963c-10's Avatar
get an oven cleaner that has sodium hydroxide, it will remove the anodization. used it on my 63 grill. Check out the link below
http://67-72chevytrucks.com/vboard/s...d.php?t=501423
1964 Short bed trailer
Old 05-28-2013, 12:41 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here are a couple more threads on the topic:
http://67-72chevytrucks.com/vboard/s...light=anodized
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-20-2014, 12:16 PM   #9
rideblue00
rideblue00's Avatar
just a bump...
