Old 05-29-2013, 07:57 PM   #1
Steve Cole
"Cut to fit" plug wires a bad idea???
I bought a set of billet wire looms for my SBC 350 and now my plug wires are too short. I noticed the "cut to fit" wires come with a stripper/crimper included and is supposed to give good results but I am very skeptical. If I can't get "factory like results" then I'll pass. Does anyone have experience with these do it yourself spark plug wire kits? What were your results?
Thanks!
Steve Cole is offline   Reply With Quote
Old 05-29-2013, 08:15 PM   #2
Bill Houghton
Re: "Cut to fit" plug wires a bad idea???
I haven't used them for years - the kits I got back when I used them didn't come with crimpers. The ones I used...well, I don't use them anymore if that gives you any idea. Ask about warranty. I'm on my second set of "lifetime warranty" plugs on my little Volvo because the insulators fell apart. It took a little, but minimal, discussion with the parts house to get the replacement set free. That's worth spending a little more for.
Bill Houghton is offline   Reply With Quote
Old 05-29-2013, 08:39 PM   #3
cdowns
cdowns's Avatar
i have been using taylor cut to fit for many years and quite a few different types of motors// having good tools to do the job and planing everything well b4 cutting anything and you can end up with a nice clean troublefree job that lasts and looks great for years and years
Old 05-29-2013, 08:39 PM   #4
Lee H
Lee H's Avatar
With a quality set of cut to fit like Taylor or MSD you can get very good results that fit your set up correctly. The last few years I've been buying MSD wire, boots, and terminals in bulk and making my own. A quality crimper is a must.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-29-2013, 08:40 PM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Just bought a set of Taylors. It really IS the ONLY way to go. The manufacturers really don't know what your exact engine config is. The only way to mount them really clean and out of harms way is when you decide each length.
prostreetC-10 is offline   Reply With Quote
Old 05-29-2013, 10:11 PM   #6
elf w/capital T
Oh wow, I've never noticed that they come with the crimpers, maybe thats why they where so pricey for the 8mm...??
elf w/capital T is offline   Reply With Quote
Old 05-29-2013, 10:19 PM   #7
Longhorn 70
Longhorn 70's Avatar
I just installed a set of cut to fit MSD wires. It took about 45 minutes to measure, cut, and install. Haven't run them through the hops, yet.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 05-29-2013, 10:25 PM   #8
Lattimer
Lattimer's Avatar
Cut to fit is the only way to go. Otherwise you always wind up with a bunch too long and at least one way too short and it looks like hell.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-29-2013, 10:46 PM   #9
Chvy2NV
Where are the available in bulk?
Chvy2NV is offline   Reply With Quote
Old 05-29-2013, 11:23 PM   #10
Steve Cole
Who sells the Taylor wires? Do they come with a crimper or do I need to buy one? If so, any recommendations on brands? Thanks.
Old 05-29-2013, 11:30 PM   #11
Lattimer
Lattimer's Avatar
I just bought a set of the Jegs branded 8mm wires. They don't come with a crimper, but I already have one. Nice wires, look good, and came in various configurations. I like how they came with some extra ends and wire numbering tabs to put on the wires.
I've used the no-name auto parts store brands several times with zero issues as well.
If you are not building a race engine, I don't see the need for high $$$$ wires. Mine will get changed every few years anyways, and will probably have less than 30k miles on them by then.
Shawn
Old 05-29-2013, 11:39 PM   #12
68gmsee
Active Member
68gmsee's Avatar
I've used them before with no problems after I installed. I did have a little trouble pushing the cable thru the rubber boot. Dielectric grease makes it easy to push through.
As cdowns mentioned, a good set of crimpers and cutters are helpful.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-29-2013, 11:52 PM   #13
Steve Cole
Sounds like I need a good set of crimpers; any recommendations?
Old 05-30-2013, 12:55 AM   #14
LockDoc
The Older Generation
LockDoc's Avatar
Thanks!
If you have an HEI you might try the '76 Corvette wire set. They are longer.
LockDoc
Leon
Old 05-30-2013, 01:03 AM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
http://www.summitracing.com/parts/MSD-35051/
These are the ones I have Steve. They are pricey but work great.
TBONE1964 is offline   Reply With Quote
Old 05-30-2013, 03:55 AM   #16
JointTech
JointTech's Avatar
use dish soap on the boots. they say to use some dialectric grease to help them slide over the ends. BS!! my fingers still hurt from that nightmare. I used dish soap on the last 3 and they tool about 2 minutes vs 45.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-30-2013, 07:48 AM   #17
Darren MagooGardner
what color wires came on a 72 c10? black?
Darren MagooGardner is offline   Reply With Quote
Old 05-30-2013, 08:05 AM   #18
CC69Rat
CC69Rat's Avatar
Here's my 'Cut to Fit' wires. This is the first set I have ever done and honestly I will never buy another pre-fit kit. This is the only way to go. Just take your time and a nice set of crimpers / razor blade and you'll be fine.
Billet Specialties wire looms btw..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-30-2013, 09:08 AM   #19
Lee H
Lee H's Avatar
Summit Racing.
Old 05-30-2013, 09:25 AM   #20
ulakovic22
Cut to fit is the only way to go, very easy. You just need a vice for the kits that come with a crimper. Very easy to install, I used a little WD and it was easy. Hardest part is trying to figure out how to route them so they look great.
ulakovic22 is offline   Reply With Quote
Old 05-30-2013, 09:36 AM   #21
TBONE1964
Cluster King
TBONE1964's Avatar
That is very nice and I like the wire looms. Very clean work.
I have a question about the photo. On the fuel line to the carb, it looks like there is teflon tape around the nuts to the carb? If that is true, you don't need teflon tape there. Those are flare nuts and don't require any additional sealer. This will give you a major headache in the future if the teflon tape works it way into the carb. I may be wrong in what I see but thought I would mention it.
Sorry to hack the thread and get off subject.
Old 05-30-2013, 10:38 AM   #22
CC69Rat
CC69Rat's Avatar
^^ Not sure actually. The line was in the carb when I bought it, I'll definitely check it though. Good eye Thanks man.
Chad
Old 05-30-2013, 03:10 PM   #23
Bill Houghton
Glad to hear the cut to fit wires have improved so much since I last bought some. I'll withdraw my earlier comment.
Old 06-01-2013, 10:45 AM   #24
Chvy2NV
I picked up a set of MSD 8mm Street Fire CTF. $50 bucks at PepBoys and they brought some type of plastic crimper. I haven't open the box yet. Get some pics in a few.
Old 06-02-2013, 03:03 AM   #25
Darren MagooGardner
I bought the same set today from Auto Zone that were only 29.00. First thing I noticed was they had been previously bought and returned and put back on the shelf. Someone had started crimping then returned them. I will be returning them tomorrow.
How else do you use a HEI upgrade and still route the wires factory style?? I assume you cant buy a set for a 72 c10 with both ends correct and the correct length??
