Old 05-29-2013, 08:08 PM   #1
Nhoechst
Nhoechst's Avatar
Fiberglass cowl hood questions.
Im thinking about getting a 3" fiberglass cowl hood to replace the stock one on my 72. I know that I will have to replace the hood springs also, but which ones are strongly recomended? Also I read that once springs are put on that won't break the fiberglass/stress it, the hood won't stay open without a prop rod. Are there any springs that won't put stress on the fiberglass hood, but can still keep my hood open without using a prop rod? Or anyother suggestions that will aviod using a prop rod, but still use the fiberglass hood.
Any assistance is appreciated.
Nhoechst is offline   Reply With Quote
Old 05-29-2013, 08:32 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: Fiberglass cowl hood questions.
sorry, have not heard too much good about glass hoods. But just to be honest and above board, I happen to sell steel cowl hoods. But the advice is coming from body shops I have sold parts to.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-29-2013, 09:03 PM   #3
Nhoechst
Nhoechst's Avatar
How much would you sell a 3" steel cowl hood for a 72?
Old 05-29-2013, 09:46 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
http://www.eharwood.com/catalog/HOOD...Bolt-On%29/428
Harwood lists a hood for '69-72's, but not the '67-68. At $550, you may want to weigh your options.
As for hood hinges, there are billet pieces that can be bought. If you haven't already figured it out...one thing leads to another and another and you learn that you need an endless supply of money!
Member Nr. 2770
Old 05-29-2013, 11:35 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
It is technically called a 2" cowl. Stamped steel, uses factory hinges and latch. $420 if you can pick up about 2 hours from Montpelier.
Old 05-31-2013, 02:57 PM   #6
Nhoechst
Nhoechst's Avatar
Thanks guys! Ill look into those hoods.
1972 C10, used to be daily driven and hoping to be that way again at some point.
Old 05-31-2013, 04:43 PM   #7
Robznob11
Robznob11's Avatar
Us body source sells glass hoods in light wt racing and heavy duty reinforced with steel. For bolt on they also sell springs for there hood. Also be aware that steel cowl hoods are not the golden ticket. Mine has to be pie cut down the sides so it will match the fender profile. So either way you go be prepaired to masage it to fit correct. Mine is a dynacorn from mothertruckers and was 365 when i got it. Also note that many places sell them but almost if not all are made by dynacorn, maybe not goodmarks but im not sure.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
