Old 06-01-2013, 06:07 PM   #1
Steinerj56
mechanical oil pressure gauge.
What do I need to do to swap out a mechanical oil pressure gauge for either an electrical one or a different style. I am tire of the mechanical line leaking at the back of the engine block behind the distributor and am looking for another option.
Thanks,
Joe
1972 C10 350 Auto
Steinerj56 is offline   Reply With Quote
Old 06-01-2013, 06:51 PM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: mechanical oil pressure gauge.
I think you can get a newer style oil pressure sender and run a wire from it to dash. Then find a electrical oil pressure gauge and just run power to it when the ignition is on.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 06-01-2013, 06:57 PM   #3
cdowns
cdowns's Avatar
what makes you think that your electrical sending unit will not leak just like what you have now??? both screw into the same hole
Old 06-01-2013, 09:42 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I had a local shop convert a mechanical oil pressure gauge to electric for my K20 build (see link in signature). There's no oil line into the cab just a wire and the OEM look of the gauge is preserved. This conversion can be done using a 60lb mechanical gauge replaced with electrical "innards" for 80 or 100 lb pressure.
Old 06-02-2013, 11:55 AM   #5
Steinerj56
Because the one I have now leaks where the metal line goes into the fitting that screws into the block.
Thanks,
Joe
1972 C10 350 Auto
Old 06-02-2013, 11:59 AM   #6
Lee H
Lee H's Avatar
I'd replace the line with a new one. Need to make sure you get the correct line kit, not a universal kit with compression ferules. The compression ferules will never seal to the stock fitting in the block.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-02-2013, 12:33 PM   #7
JMac11
JMac11's Avatar
I have always bought a braided fuel pressure guage hose kit, seals good, has the swivel fittings so it does twist, has fit everyone I swapped.
JMac11 is offline   Reply With Quote
Old 06-03-2013, 06:57 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Any hydraulic shop will sell you a new copper line with the proper end fittings for well under 10 bucks. That should hold you for another 40 years of leak free use.
Tx Firefighter is offline   Reply With Quote
Old 06-04-2013, 10:59 PM   #9
Steinerj56
I see autometer makes a braided steel line that comes with fittings. any idea if I need a 3,4 or 6 ft line?
Thanks,
Joe
1972 C10 350 Auto
Old 11-24-2013, 05:10 PM   #10
Vova
Do you have a part number? I need a oil pressure like kit for my gauge.
Vova is offline   Reply With Quote
Old 11-24-2013, 07:19 PM   #11
1972RedNeck
1972RedNeck's Avatar
Napa gave me the ends for free. I reused the original line.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-24-2013, 07:57 PM   #12
elf w/capital T
Never even thought about converting to an electric gauge... im subscribed
elf w/capital T is offline   Reply With Quote
Old 06-16-2015, 12:48 PM   #13
bmtsheets
replied to wrong thread. sorry. too many tabs open
bmtsheets is offline   Reply With Quote
Old 06-16-2015, 03:46 PM   #14
GRX
GRX's Avatar
Do you have the compression fitting type? I much prefer the flare type fitting. If not already, you should have a few loops in the hard line between block and firewall to absorb vibration & movement.
GRX is offline   Reply With Quote
Old 06-16-2015, 04:09 PM   #15
sKnNyPpY
sKnNyPpY's Avatar
Just replaced my old plastic leaky line with this. Works perfectly...http://shop.advanceautoparts.com/p/b...584/10717221-P
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 06-17-2015, 12:35 AM   #16
Bowed
Right on
Bowed is offline   Reply With Quote
Old 06-06-2018, 09:45 AM   #17
Auroch
Auroch's Avatar
I realize this is years old conversation, but do you still have this information available? I want to convert to electric oil gauge as well.
Auroch is offline   Reply With Quote
Old 06-06-2018, 10:09 AM   #18
DJ_Baar
I'm converting my ammeter (battery gauge) to voltmeter and was considering replacing mechanical oil pressure gauge to electrical too. See my thread, http://67-72chevytrucks.com/vboard/s...=747394&page=3
http://www.classicinstruments.com/ can hook you up with the switch-over if that is what you want.
DJ_Baar is offline   Reply With Quote
Old 06-06-2018, 03:31 PM   #19
Zeroman
Zeroman's Avatar
I converted my Oil Pressure gauge to electrical using a mid 80s gauge and sending unit.
I had to modify the instrument cluster backing plate and the gauge mounting bracket to make it fit.
I also do not have the original wiring harness, I have a Painless Wiring harness which already includes an electrical oil pressure circuit. The only thing I had to do was figure out which connection on the back of the gauge was hot, and which one was ground.
The sending unit is much larger than most so it required a 45 degree fitting so it would miss the HEI distributor.
I think it turned out pretty well.
Zeroman is offline   Reply With Quote
Old 06-06-2018, 03:42 PM   #20
DJ_Baar
Looks GREAT! Got any pictures of the back?
I'm installing a complete American Auto Wire (AAW) Upgrade in my truck now, so NOW is the time to make this all good.
DJ
Old 06-06-2018, 09:23 PM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
A local gauge restoration shop did my conversion. Here's their website: http://www.momamanufacturing.com
Old 06-06-2018, 11:50 PM   #22
Auroch
Auroch's Avatar
Man, yes. If by switch over you mean maintaining the original look of the cluster. I’m all ears.
Old 06-06-2018, 11:52 PM   #23
Auroch
Auroch's Avatar
I’m also working with painless wiring, i ripped all old wiring and completely replaced (replacing). Any links as to what you used? Looks nice man.
Old 06-07-2018, 06:50 AM   #24
Zeroman
Zeroman's Avatar
Here's a link to the style gauge I used.....
https://www.ebay.com/itm/vintage-NOS...sAAOSwBSxbGENf
The sender is from the same year models. I think I bought it through rockauto.com. You just need to make sure if you use a 60 PSI gauge to get the 60 PSI sender. Same for the 80 PSI gauge, use a 80 PSI sender.
No, unfortunately I do not have any pics.
The install was pretty simple. I used a dremel tool to cut away some of the metal out of the back side of the cluster. I seem to remember I had to bend the edge to the gauge face back to make it fit. Also, I think the gauge is only held in place by the one screw on the face of the gauge. It was not a real "pretty" job from the backside of the cluster.
Old 06-07-2018, 07:05 AM   #25
DJ_Baar
Check-out this link I got from Cliff at CLASSIC Instruments.
http://shop.classicinstruments.com/other-2-18-gauges-5
Have not tried yet and asked Cliff a couple questions about how to make these work.
