Old 06-03-2013, 07:35 PM   #1
jayoldschool
Moderator
Just finished cutting my TREX bed wood!
Went well. Thought TREX would be a great choice for a truck that will sit out in the elements. Got a great deal on overstock that was sitting unused outside. Used the dimensions from GMCPaul's site. This is for my LWB 65 C10 Fleetside. The boards were 1"x8"x12'. Took about three hours total for measuring, cutting to length, ripping, and grooving. Boards were cut to length with a circular saw, but all other dimensions were done with a radial arm saw (ripping blade, and a dado blade).
Can't wait to install it!
Wood, non-polished strips/bolts will be a nice upgrade:
jayoldschool is offline   Reply With Quote
Old 06-03-2013, 07:37 PM   #2
gofastnut
gofastnut's Avatar
Re: Just finished cutting my TREX bed wood!
Looks good man!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 06-03-2013, 07:46 PM   #3
Fastrucken
Junior Member
Fastrucken's Avatar
I wanna see how this turns out... How much did you pay for it??
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 06-03-2013, 07:48 PM   #4
Sharps40
I'm looking at trex for John Lee Jr this summer. How does it mill? I'm gonna use carbide dado head on the table saw. Was wondering if it'd gum up the blades or cut smooth.
I plan to use the 3/4" thick trim boards so the fit is the same and add a couple cross ties to put it all on 16" centers.
Sharps40 is offline   Reply With Quote
Old 06-03-2013, 07:56 PM   #5
Blue666
Looks great. If your mufflers are under your bed, really look at installing a heat shield.
Blue666 is offline   Reply With Quote
Old 06-03-2013, 08:00 PM   #6
BMERDOC
BMERDOC's Avatar
Looks great! I wish I was better with wood and had the tools to do it.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-03-2013, 08:38 PM   #7
jayoldschool
Moderator
I will be running a stock muffler, and I will build a heat shield for it.
I paid 25/board. List was 60ea! Expensive, but no sanding, no priming, no stain/paint. Ever.
It cuts easily. Easier than lumber, I would say. No "gumming", the waste just spiraled off. No problem for the old circ saw blade, and it just glided through the radial arm with no pressure. With two people, the long boards were easy to push/pull through. Toughest part was getting them down the basement to the workshop! We cut them all to length in the garage, no way 12' would have made it.
I decided to go this way after doing lots of research on this forum. A few have done it, so I wanted to try as well.
Old 06-03-2013, 08:50 PM   #8
Sharps40
Okay, its decided then. John Lee Jr is getting trex this summer!
Old 06-04-2013, 03:06 AM   #9
donthekawguy
donthekawguy's Avatar
I'm going to powdercoat the strips and get new shiny bolts. Just an idea for ya.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-04-2013, 08:09 AM   #10
Clyde65
Clyde65's Avatar
Only thing with Trex is it comes in 6" width only. more boards but if it lasts as it should, your truck will never need new boards again.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-04-2013, 08:25 AM   #11
Sharps40
Actually, the trim boards from trex and various other makers come in 1x12 dimension and actually measure 3/4" by 11+" inches wide. Perfect for milling and cutting out bed boards. Add a couple cross ties though cause even the inch trex needs to be on 16" centers and theres a couple spots in the bed where more support would be needed. I plan to use the Grey trim boards from lowes. They are not trex but are only $27 each for the 12 footers at 3/4" by about 11 1/2" wide.
Old 06-04-2013, 10:02 AM   #12
jayoldschool
Moderator
Trex comes in many different sizes now. My boards are 1"x8"x12' (dimensional, as Sharps pointed out), the perfect size to match OEM boards. Also, my boards aren't "decking", they are "facia" boards.
Old 06-04-2013, 10:11 AM   #13
JWheeler331
JWheeler331's Avatar
Looking forward to seeing the project as it progresses.
JWheeler331 is offline   Reply With Quote
Old 06-04-2013, 10:14 AM   #14
1963c-10
1963c-10's Avatar
x2....I'd definitely put heat shield on. Easy and cheap insurance.
1964 Short bed trailer
Old 06-04-2013, 12:27 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I did a bed with trex a bit back, and it's held up great so far, tho I used the decking style pieces not fascia. I didn't mill them to accept the trim strips, instead I made psuedo-trim strips to fit the gaps. I plan on bedlining the whole thing to give it one contiguos look.
Did you plan on painting/coating yours?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2013, 02:39 PM   #16
jayoldschool
Moderator
No, I purposely picked grey so it looked like old weathered wood. It will be appropriate for the truck.
Old 06-04-2013, 03:32 PM   #17
Clyde65
Clyde65's Avatar
I stand correct, my apologies. I looked at my local Lowes and they only show the 6" deck boards. I didnt even know they had facia boards or ones that are 1X12's. Good to know, thanks guys!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-27-2013, 05:30 PM   #18
jayoldschool
Moderator
Back with an update. I've been busy with other projects, but finally got new crossmembers and front panel installed. Wood is in place, strips and wheel houses go in next.
Old 08-27-2013, 09:41 PM   #19
joedoh
joedoh's Avatar
outstanding
Old 08-27-2013, 09:47 PM   #20
Sharps40
Awesome....Mine is looking good so far...only about a month old but I like the way when its dirty, a drive in the rain pretty much cleans it off, no scrubbing!
Old 08-28-2013, 12:26 AM   #21
jtrichard
check this out 3/4x 11 1/4 x 8' $30 lowes choicedek foundation http://www.lowes.com/Decking/Composi.../N-1z10sn3/pl#!
jtrichard is offline   Reply With Quote
Old 08-28-2013, 05:32 AM   #22
Sharps40
That's what I used on John Lee Jr. Its advertised at 3/4" but its true thickness is 5/8". Seems sturdy enough. I got it on sale, $18 or so per board. Looks wonnerful in the bed.
Old 09-04-2013, 07:13 PM   #23
jayoldschool
Moderator
Making progress...
A few more bolts to snug down. Middle two boards will be installed after the bed is back on, I need to be able to strap around the cross members to lift with my engine hoist.
Old 09-04-2013, 07:38 PM   #24
Sharps40
Damn nice.
Old 09-04-2013, 08:52 PM   #25
jayoldschool
Moderator
Those are unpolished strips. They will be the nicest parts on the whole truck! Black would have fit better, but it's going to sit outside in the snow, so I thought stainless would be a better choice than steel.
