Old 06-03-2013, 09:33 PM   #1
oldsmobilekindofguy
Ram assisted steering question
I have a 67 c10 with the ram assisted steering and i was wondering if anyone has converted theirs to integral powersteering and what all it entailed. I know i'll need a steering box and maybe a center link but just checking to see if anyone else has done this and what all was needed. Any help would be appreciated thanks in advance.
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 06-03-2013, 09:54 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Ram assisted steering question
The frame on a 67 isn't dimpled for the PS gearbox.You can use one up to IIRC 86 but may have issues with the hose fittings since they changed in about 78.The dimple procedure is pretty simple and the arts are more easily available.I believe the center link is the same but not sure.There have been a few write up son this.If you do a search you'll find lots of info.Keep in mind that when you get the PS get ALL of it.Pulleys and brackets can be a nightmare if they aren't a matched set.Also PS brackets are engine specific,meaning you'll need bb fo a BB and 250 is diff from 292.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-03-2013, 10:18 PM   #3
oldsmobilekindofguy
Is the dimple for clearance or for mounting the gearbox?
Old 06-04-2013, 08:09 AM   #4
PanelDeland
http://67-72chevytrucks.com/vboard/s...d.php?t=582870
Here's a link to a thread on this.The dimple is for mounting the gearbox.It has a slight protrusion that does not let it mount against the frame without the dimple.They also make a spacer to set it out from the frame though some report problems.I believe this is because they don't adjust to "center" the gearbox but haven't done one myself.
Gearboxes for the 68-72 trucks are 4 1/2 turns lock to lock.Later 73 up are 3 1/2 turns.I prefer the later box since it has a stiffer feel to it.The 68-72 boxes feel somewhat "mushy" to me.You can use either but will need to use the pitman arm for the year of suspension.
Old 06-04-2013, 08:24 AM   #5
PanelDeland
Here's a thread with some good links on it.
http://67-72chevytrucks.com/vboard/s...t=frame+dimple
Old 06-04-2013, 11:58 AM   #6
oldsmobilekindofguy
Thanks for the information
