Old 11-25-2003, 01:23 AM   #1
72superBB
72superBB's Avatar
Question Posi or limitedslip?
Has anyone out there( Iknow someone has) taken a rear end with limited slip or posi out of later model trucks and put in their 67-72? I currently have a one wheel burnout monster of a truck, but want more traction. I am sure there has to be some modifications for that to be done. WHat other options are there out there? Can I replace the insides of my rear axle to accompolish this?
thanks minus one side!
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 11-25-2003, 01:36 AM   #2
jhow66
jhow66's Avatar
Had same problem. Got a Eaton Posi unit from Reider Racing. (other places carry it also). All you have to do is take your ring gear off your present carrier and install it on the new Eaton carrier and reinstall in rear end. I didn't have to adjust anything. Piece of cake. Now I can lay down 2 lines of rubber.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-25-2003, 03:48 AM   #3
Injected68LS1
Injected68LS1's Avatar
Check out www.markwilliams.com. Under their specials section they have eaton posi for $310. That's a deal if you can afford a new one. You can usually pick up new gears for another $150 and bearing kit for another $100.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 11-25-2003, 03:57 AM   #4
gonebad2
Merciless Butcher
gonebad2's Avatar
Nothing beats a good two legger burnout.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-25-2003, 04:08 AM   #5
dinnut
dinnut's Avatar
http://nationaldrivetrain.com/shopsi...ml/page35.html
like 350 for a new 3.73 eaton posi
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-25-2003, 09:25 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I paid $280 for my Eaton at www.tomsdifferentials.com
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-25-2003, 10:49 AM   #7
72superBB
72superBB's Avatar
So how many different parts will I need to switch out my current setup?
I know I need the eaton posi unit.
What are the gears and the bearing kit?
jhow66 says use existing gears and Injected68LS1 says to get new ones.
THanks guys
1990 Chevy SWB
Old 11-25-2003, 02:32 PM   #8
70c10
67-72 Addict!
70c10's Avatar
I paid $25 extra for new bearings and races. I reused my 3:73 gears.
Jim
Old 11-25-2003, 02:40 PM   #9
PR454SS
PR454SS's Avatar
I checked that link, pretty good selection of gears for the 12 bolt, any one running the 3.91 to 1 gears they offer? Looks like it might be a good comprimise between 3.73 and 4.11
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 11-25-2003, 02:43 PM   #10
72superBB
72superBB's Avatar
What gear ration should I use for my truck?
402 BB
Turbo 400 tranny.
I think it currently has 3.07, but I am not for sure.
1990 Chevy SWB
Old 11-25-2003, 02:55 PM   #11
70c10
67-72 Addict!
70c10's Avatar
What is the intended use and what tire height are you running?
Jim
Old 11-25-2003, 02:57 PM   #12
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Well, where do you drive it...
I mean, do you use the truck for just cruizing around town, interstate driving, hauling/pulling?
A 3.07 would be great if you drive the truck long distances, it will help your mpg.
If you stay in town or tow, I would choose a 3.73, or even a 4.10 for more grunt
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-25-2003, 04:35 PM   #13
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I have 2 12 bolt 3.73 rear ends 1 wheel peel, would it be best to put the eaton posi unit in rather than buying a complete rear end ??
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 11-25-2003, 06:49 PM   #14
jhow66
jhow66's Avatar
72superBB I had the same setup as yours ( 402-400turbo-3.07 gear). If it is your daily driver the 3.07 will be fine. Just add new carrier bearings like the other guys say. That plus a gasket and Posi fluid will be all you need.
