Old 06-04-2013, 07:24 PM   #1
Agent915
Fuel line routing
Hey folks,
Dropped my engine/transmission in the frame. I will run all new fuel/trans cooling lines. I want to reroute the fuel line down from the pump, under and up the backside of the engine to the carb. Do any of you know if a pre-bent line is available for this routing? I'm trying to hide everything I can! Or, maybe someone has a better suggestion to hide the line. Open to ideas. The engine is a 454.
Thanks!
Agent915 is offline   Reply With Quote
Old 06-04-2013, 07:40 PM   #2
JimKshortstep4x4
Re: Fuel line routing
I don't know of any prebent lines but you might consider going with an electric fuel pump as an option. This would make it easy to run the line from the backside of the engine.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-04-2013, 08:16 PM   #3
Agent915
Jim
Thanks Jim. I hadn't even thought of running an electric pump. What type would you suggest? My carb is a "Quick Fuel". Not sure of the CFM's.
Old 06-04-2013, 08:48 PM   #4
zeeklu
Pick up a bender and some line. Both are cheap. Play around you might be surprised. Chris
zeeklu is offline   Reply With Quote
Old 06-04-2013, 09:02 PM   #5
Agent915
I had thought about bending my own. A friend of mine has the bender and a flaring tool. I may give it a try just to see if I can do it.
