Old 06-05-2013, 08:28 PM   #26
Rufton
Re: 1999 350 vortec K1500 head gasket
Hit a lil snag.
The intake is pitted around coolant ports; probably in leaky regions.
Otherwise nearly zero coolant corrosion found.
K1500 had fresh coolant most of it's life.
Probably lay down some Ultra RTV and go for it.
Will think about having it surfaced but may give RTV a try first.
Rufton is offline   Reply With Quote
Old 06-05-2013, 10:32 PM   #27
truckdude239
truckdude239's Avatar
They are all like that i just rtv it and go
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-05-2013, 10:37 PM   #28
clinebarger
That's not bad at all compared to some. If you use the Good Fel-Pro gaskets it will most likely not leak.....But I put a very small bead of Ultra Grey around the water ports of intake manifolds on ALL engines.
clinebarger is offline   Reply With Quote
Old 06-16-2013, 03:57 PM   #29
Rufton
Four bolt baby!
Runs like a dream.
Healthy as a horse; leaks not a drop.
Mistake I made was not replacing the OEM spider; the old spider fouled passenger bank plugs. Penny wise pound foolish. I though I was careful w/ OEM spider but I guess not. Put new design spider in and all is well.
Already dumped first run oil and looks good; will dissect filter later. All I can do not to red line it but I'll try and behave till 500 miles in.
Old 06-17-2013, 09:22 PM   #30
Rufton
Originally Posted by clinebarger View Post
The gaskets are a bad design, Dexcool is not to blame for that.
Before tossing the gaskets I gave them a brief inspection.
The rubber like seals had little elasticity and broke very easy; not sure what to blame but pretty sure they would be more robust and elastic when new.
The plastic support for the rubbery seals easily broke also.
Old 06-25-2013, 11:58 AM   #31
Rufton
Look's like the new vortec is a keeper.
Smooth as silk and filter elements looks good.
