06-06-2013, 04:56 PM | #1 |
Rear Sway bar options?
Looking for info on rear sway bars for our trucks... actually '60-'72.
What are some companies that make rear bars, and how do they attach to the truck? Even a list of companies that make them, and/or some installation instructions would work. I went to Hellwig's site, but it was slow and borderline useless. Thanks, -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
06-06-2013, 07:17 PM | #2 |
member #16
Re: Rear Sway bar options?
Here's some info to sift through.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-06-2013, 08:51 PM | #3 |
I Googled "Hellwig" and found this link for a seller in addition to the Hellwig site. It has Hellwig and another brand. Maybe it'll help.
http://www.suspensionconnection.com/...ry=Sway%20Bars I put a Hellwig rear bar on my 69 in 1971 and took it off when I started my restoration a couple years ago. I bought it to help handle the large cab-over camper. I won't be using it again. |
06-07-2013, 12:38 AM | #4 |
Thanks guys.
Someone told me there's one that attaches by the shock mounts, or that area. Anyone seen that? -Brad
06-07-2013, 08:13 AM | #5 |
Then there are threads like this where people have used camaro sway bars. I'm just not sure which year.
06-08-2013, 11:01 AM | #6 |
addco is another who makes bars
06-08-2013, 12:34 PM | #7 |
motor exploder
I haven't looked to see if Addco makes a '60-72 rear bar, but I've used their rear bars on two different trucks ('92 C1500 & '05 Sierra 1500) and the installation was pretty straight forward with very good instructions. It's probably worth the time to just give them a call.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-08-2013, 01:40 PM | #8 |
i have this one i pulled from a 2wd 78 square blazer at the jy of course the blazer had leafs an i tried fitting this one too my coil spring suspention forwards reverse up side down and i just cant get it too work properly
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-08-2013, 01:49 PM | #9 |
70+ ( Old Skool Club )
Looks like Addco makes a 7/8 inch bolt on rear bar for our trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-08-2013, 01:55 PM | #10 |
I have cpp's rear swaybar on my 71 and it just bolted on was really easy and a very nice product.
Posted via Mobile Device |
06-08-2013, 04:57 PM | #11 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-08-2013, 05:39 PM | #12 |
06-08-2013, 06:03 PM | #13 | |
I like to see one installed. Does it install behind or in front of the axle?
06-08-2013, 08:10 PM | #14 |
Here is some pics of my Addco rear bar
Fuzzy |
06-09-2013, 05:16 AM | #15 |
The coil versions seem to mount to the flats of the factory trailing arms, I'm planning on using the Porterbuilt tubular arms is there a sway bar that would easily work with those?
