06-06-2013, 10:31 PM | #1 |
Lets see your bed wood.
I'd like to see bed wood in either kit or homemade. Even diamond plate or whatever you have.
06-07-2013, 05:18 AM | #2 |
Re: Lets see your bed wood.
06-07-2013, 06:01 AM | #3 |
Watch out for your cornhole !
I did this because it was free. A bed floor out of a 78 longbed truck. I just cut it down. Reused all of the original under floor braces from the longbed and everything.
Posted via Mobile Device |
06-07-2013, 06:24 AM | #4 |
nice job on the metal floor
06-07-2013, 07:16 AM | #5 |
haha, bed wood. I dont think that they allow those type of pics.
I im going to put the orignal wood back in after my 74 box is painted. My 75 I used a oak kit with ss everything
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
06-07-2013, 08:07 AM | #6 |
06-07-2013, 09:20 AM | #7 | |
I like to keep things original; here is a picture of my Black 77 Stepside. I hope the picture comes out OK to see.-Larry |
06-07-2013, 09:59 AM | #8 |
06-07-2013, 11:06 AM | #9 |
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
06-07-2013, 12:17 PM | #10 |
Those tie downs seem like a real good idea...Might have to install some of those myself.
06-07-2013, 02:11 PM | #11 |
I hope to install a shinny new wood bed one day.
The diamond bed is heavy and heavy duty; not good for mpg. |
06-07-2013, 02:29 PM | #12 |
06-07-2013, 07:50 PM | #13 |
the tie downs went in nice no problems had to dremel some wood to make them flush fit but the seems to be ok
06-08-2013, 12:57 AM | #14 |
soon to be in the truck! Lol
06-12-2013, 09:45 PM | #15 |
06-12-2013, 09:46 PM | #16 |
Some cool stuff. Any more??
06-12-2013, 10:00 PM | #17 |
I reused all of the crossmembers and supports from the longbed. By cutting the floor front and rear, I kept the supports in the same places where they originally fell on the longbed configuration except with the front and rear chopped off for the now short bed configuration.
If you look closely in the last picture, just above the hammer handle and near the pliers you can see that I reused the original bed mount bolts and spots that were embossed in the longbed floor. I did have to drill the two front most mount holes, but the spots were basically there in the frame. I just bolted the rest of the bolts down and passed a drill down through the front pair of holes through the frame rails. The holes already being in the bed floor acted as a drill guide to pass the drill down through without a bunch of tedious calculations. Posted via Mobile Device |
06-12-2013, 11:29 PM | #18 |
Cool, thanks. Im trying to figure out how to bolt a bed down withot the bolts showing.
06-13-2013, 05:58 AM | #19 |
Old Heap Driver
Looks factory, nice job!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
06-13-2013, 06:16 AM | #20 |
Old Heap Driver
4X8 sheet of 3/4" cabinet grade plywood cut into 12" boards coated with clear poly. These are old pics I've since added stainless strips and chrome screw covers.
In one pic you can see a 2X4 at the rear cross sill. 2X4's are bolted across all the cross sills to raise the floor (air ride) and provide a mounting point for all the screws holding the floor in place.
06-13-2013, 06:43 AM | #21 |
Weld the bolts to the crossmembers first and then all you have showing are the metal strip bolts that hold the wood down.
06-13-2013, 02:46 PM | #22 | |
06-13-2013, 02:46 PM | #23 |
06-13-2013, 02:47 PM | #24 | |
06-13-2013, 07:39 PM | #25 |
Old Heap Driver
No sorry.
