06-08-2013, 10:18 AM | #1 |
60-62 ho32 rear end question
How do I remove the axles so I can get the lugs re-drilled for 5 lug?
Thanks! Posted via Mobile Device
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-08-2013, 10:28 AM | #2 |
Re: 60-62 ho32 rear end question
Take the drums off, rear cover off, push axle inward, remove c-clip with magnet. Pull pin. Pull axle out.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
06-08-2013, 12:20 PM | #3 |
I got it, I had to remove a long screw that held the large pin in, remove pin and push axles in, c clips fell out, then pulled the axles.
Thanks for your help LVphoto! Posted via Mobile Device
