Old 06-08-2013, 03:06 PM   #1
vjjack04
vjjack04's Avatar
lowering stock rear leafs
Guys,
I want to lower the rear of my 55 about 1 inch....is there a shackle bracket that would do that.....I think I could make one, but don't want to if I don't have to....
vjjack04 is offline   Reply With Quote
Old 06-08-2013, 03:53 PM   #2
mknittle
mknittle's Avatar
Re: lowering stock rear leafs
To get one inch the shackle would have to be shortened 2 inches. that would make the shackle too short and cause at best a harsh ride. At worst a bent spring or other suspension part.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-08-2013, 04:03 PM   #3
vjjack04
vjjack04's Avatar
how about removing a leaf or so...?
Old 06-08-2013, 04:28 PM   #4
mknittle
mknittle's Avatar
You could do that if you don't remove too many and just the short ones.
Mark
My GMC build.
Old 06-08-2013, 06:51 PM   #5
Stepside Jim
Accually, you'd have to lengthen the shackles on the rear.
Stepside Jim is offline   Reply With Quote
Old 06-08-2013, 08:28 PM   #6
vjjack04
vjjack04's Avatar
Jim,
That is what I see....It looks like I could get some metal (looks like about 1/4 plus) plate, cut and drilled to accept the bolts would work....I would thin 2" longer would do....does any one make these?
Old 06-08-2013, 08:43 PM   #7
GMtrucknut!!
GMtrucknut!!'s Avatar
POL makes lowering shackles I remember seeing them in their catalog.
GMtrucknut!! is offline   Reply With Quote
Old 06-08-2013, 11:20 PM   #8
Stepside Jim
Originally Posted by vjjack04 View Post
Jim,
Ok, when mentioned earlier, you'll only get about half the drop as to the length of the addition of the shackles.
If you can't buy them and need to make them, I think I used 3/8 thick. The thickness is needed because the shackle has a taper built into it to accept the taper that is a part of the pin.
The fit has to be somewhat close, referring to the depth of the taper, so the rubber sealing ring will contact the spring eye and the shackle to keep crud out of the greased area.
I drilled the shackle holes to the size of the pin thread, then used a rotary brrrr to create the taper. Took a little patience, but worked well.
Good luck, Jim
Old 06-09-2013, 09:20 AM   #9
GMtrucknut!!
The biggest issue with making them is getting the taper right on the bushing ends reamers can be purchased at most machine shop suppliers. When it comes to suspension I do not ever cut corners , if you get involved in an accident with a modified vehicle it just leaves the door wide open to lawsuits in our lawyer plagued world.
Old 06-09-2013, 12:18 PM   #10
_Ogre
_Ogre's Avatar
can't you flip and swap the rear shackle hangers on these to get an inch of drop ?
or remove the overload springs in back, just the 2 short ones, that would give you 3/4 inch with little effort
shop air compressor timer
Old 06-09-2013, 12:24 PM   #11
mknittle
mknittle's Avatar
I was thinking front
Mark
My GMC build.
