![]() Join Date: Jun 2013
...good and clean rebuilt transmission and chevy small block with heavy duty and performance parts
-solid street performance power train that was pulled and replaced with more power and performance and is no longer needed -GOOD PRODUCT TAKEN CARE OF RESPONSIBLY...MANY ITEMS IN ORIGINAL PACKAGING- ALL-IN-ONE SALE....NOT FOR SALE INDIVIDUALLY/PER PIECE 1973 K10 4-bolt engine (3970010/K0621TJZ), with fully-ported 882 heads has only~1000 miles since professionally rebuilt 1969 Caprice heavy-duty TH350 (Y9K 22D/CFD4) was pulled a little later and has only~1800 miles since professionally rebuilt EVERYTHING CLEANED FOR REUSE; MORE THAN $2500 IN ACCESSORIES AND AFTERMARKET PARTS ALONE; Edelbrock Elite cast aluminum air cleaner assembly chrome air cleaner- drop base TransDapt 1" air cleaner spacer K&N air filter 15x4 K&N aerosol filter cleaner and oil Edelbrock Performer RPM 850cfm quadrajet #1910, including gaskets, rebuild kit, race calibration kit, and tech. Edelbrock 1" 4-hole q-jet spacer; treated hdf Moroso 2" aluminum q-jet riser/adapter (for square bore manifold) Edelbrock Performer RPM q-jet manifold Edelbrock Elite cast aluminum valve covers Edelbrock Elite cast aluminum breather; new filter media Moroso steel-core valve cover gaskets Accel HEI distributor Accel header plugs MSD 8.5mm wire set & extra boots & terminals dist springs/weights kit adj. vac advance modules aftermarket distributor hold down/clamp Moroso aluminum distributor housing/bushing with nylon shim washers gear drive with offset bushings 1.5" accessory belt-drive kit Lunati Voodoo camshaft #60103 Comp Magnum hardened pushrods Comp Magnum roller rockers Warner high-flow thermostat ARP 12 pt. head bolts, 12 pt. damper bolt, heavy duty flexplate bolts Professional Products sfi damper billet timing pointer stamped timing pointer GM Performance head gaskets with stainless fire rings- installed, never run GM Performance intake gaskets- new set stainless-laminated composite exhaust gaskets- new set Moroso oil pan & pick-up, reconditioned; new enamel Melling oil pump 55 1.94/1.50 iron 882 heads, ported: intake 2.18x1.35, exhaust 1.48x1.38, 65cc combustion chambers, pinned studs 4 bolt block, 2 pc. rear main seal, balanced hyper flat tops with valve reliefs 4.060" bores -honing patterns still present- good ring seating 9.16:1 compression ratio B&M uni-matic shifter- no cable, no knob Hughes Performance gm2500 torque converter, AND hd 1800 stall converter chrome torque converter cover sfi flexplate Lockar kickdown cable- new hard tube/dipstck, transmission- new heavy duty TH350; 2.42/1.42/1:1 hardened sprag, 5-pack, yellow frictions, shift kit, adj. modulator...(i ran with B&M trickshift) transmission oil cooler Weiand team action water pump- surface rust removed; flushed/cleaned; new polyurethane, good impeller, no play chevrolet stock starter chevrolet early power steering pump misc. fans fan spacers and bolts misc. bolts, gaskets, brackets, etc. engine and trans were painted with high-solids polyurethanes- still looks good... original product literature, instructions, and stickers; in a binder boxes and bags for all items; can be shipped- i can build a bolt-in crate if needed, you pay cost on freight/delivery... $3500 obo |
