#26 |
Re: Project "It's a Jimmy Thing"
Nice work. Really smart way to get that shaft cut straight! I need a mentor check... lol. Nobody ever showed me that one. Now I'm realizing it's the way to cut bolts, etc. Now you've got me feeling dumb.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#27 |
Boosted Member
Nice build!!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#28 |
![]() Join Date: Jun 2012
Thanks! It was the only way that i could come up with to cut the shaft some what straight with out having to take it back out.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#29 |
Thanks! Your blazer build is pretty sweet too. Sorry about the engine. I'm not putting turbos on this one, but i have a 51 5 window that will get them someday. I will be looking for a build thread on your 69.
#30 | |
Boosted Member
#31 |
A few pictures of the fuel lines and fuel pump hanger.
#32 |
I installed a Entropy radiator. I called Tony at Entropy and he built me a standard radiator and changed the inlet and outlet pipes to the ls sizes and installed a steam port connection. I liked the standard radiator over their ls swap radiator for a couple of reasons. I could use standard 2003 truck hoses, the tranny cooler is on the passenger side and it made it easier to route the lines and the radiator cap is not hanging right over the battery. I tapped the water pump for the temperature sender like many have done. I also stole an idea from ls1nova71 on this board and cut the battery tray apart and swapped the sides so it essentially made a mirror image of itself and could be mounted on the drivers side. I still need to fit the inner fender to make sure it clears before i blast and paint it.
#33 |
More pictures.
#34 |
![]() Join Date: May 2006
Nice build, enjoying the info.
Im getting ready to run fuel lines, and could use some help, info. Did you say they are earles fittings and fuel lines Are using a tip over vent?
#35 |
I stole another idea from crash on this board and mounted the computer under the dash like he did. I also fit the harness to the firewall and mounted the DBW pedal.
#36 |
Thanks. No, i am using Swagelok style compression fittings and stainless tube for the main runs and Russell AN fittings and proclassic hose for the flex connection up the back of the engine. You can get a 20' length of tube at a piping supply house for like $20.00 and the fittings are a couple dollars a piece if you get Bilok or Parker brand (SwageLok brand is expensive). They are good for alot of pressure. I have personally used them on high pressure steam and lube oil systems. The hard part is bending the tube. I suck at it. lol. I am using a roll over vent it is in the top of the fuel pump hanger. Let me know if you have any more questions. I would be glad to help.
#37 |
I hope you're being sarcastic, it's like tubing artistry.
#38 |
Yeah, im familiar with swageloc, used to work for a small company that built cats for diesel engines...cool stuff
Thanks for the info., ill check it out Your welding skills are impressive, you may be bad at bending ( looks good to me )but, i really suc at welding ![]() Did you buy the roll over vent from someone? Does the fuel line fray like ss braid?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-11-2013 at 01:17 PM. |
#39 | |
The roll over vent came with the fuel pump hanger which i got from Tanks Inc. I also got the Walbro pump and level sender from them as well. If i was going to do it again i would either find a pump hanger that was a little higher quality or build my own. I am sure that it will work fine but the flange part that mounts down to the tank is a little thin and flimsy and the lines are just soldered in to it. I have never used the Russell SS stuff before but i have heard horror stories about it. The proclassic hose is just rubber hose with a fabric braid around it. It will not rub on the frame or other painted surfaces and take paint off. It will fray if you are not careful when you cut it. I wrapped teflon tape around where i was going to make the cut and then i cut through the center of the teflon tape with what i call "reed" cutters. Then took the rest off the teflon tape back off of the hose and installed the ends. The reason i used teflon tape is because it is not sticky so when i pulled it back off it would not unravel the fabric braid. I hope that this makes sense.
#40 | |
[quote=skorpioskorpio;6118374][QUOTE=JJH Jimmy;6118234] The hard part is bending the tube. I suck at it. lol.
#41 |
![]() Join Date: Mar 2009
Another great build to follow along with. I can’t be the only one here that really appreciates you taking the time to share what you have done but what really helps is explaining what you used. I absolutely hate searching for parts, ideas and or quality vendors/manufactures. Keep it coming. (No details are too small to share either)
#42 |
Really nice build coming together, should be a dream to drive. custom exhaust heat shields look great along with (Everything)...else. Is the silver firewall a teaser of whats to come?...and If your dog is done with the welding coat (Post#4) pass it on..some of us could use it.
#43 | |
I feel like i needed to start this build thread to give back to the site all of the great information that i have gotten from it. I only wish that i would have started a year ago on day one of the build. If anyone has any questions of things that i have done please feel free to ask.
#44 | |
#45 | |
ok, i will have to search for the rollover vent, my 2002 f body fuel pump should be coming in tomorrow i have plans to use a nickle/copper fuel hard line, should be easier to work with. and thanks for the tip on the teflon tape. im guessing that proclassic is ok to use for FI?
#46 | |
http://www.tanksinc.com/index.cfm/pa...prod/prd98.htm The Proclassic hose is rated for 350 psi i believe.
#47 | |
Seems like your fitting in well around here, invalueable info. provided
#48 | |
Who did you get your exhaust pipe from? Was it just a bunch of bends or was it more of a vehicle specific kit or …? |
#49 |
The exhaust pipe is 2 1/2" stainless steel sanitary tubing scraps that were left over from a job at work. I also got a few 90 bends as well. I cut the stock manifold flanges off of the down tubes that came with the engine and welded them to the stainless tube and welded stainless oxygen bungs that i got from summit to the tube. I just cut and mitered the fittings for the angles i needed and purge welded everything together. It took for ever to do, but it turned out better than expected. I still have to finish up the exit pieces after i get the body back on. I got the stainless Borla mufflers from a place called Street Side Auto for $65.00 a piece! I used the band clamps from them because i was worried that it would be to loud for my tastes, but after a test run of the engine it sound great. I may take the band clamps off and weld them in as well now.
#50 |
I sent the harness and computer to Speartech. John modified my original harness to stand alone and flashed the computer. Before i sent it out i emailed about six different companies that do this and Speartech was the only one that responded! After i got it back i had a few questions and he has always called me back. I would highly recommend using Speartech. If i do another swap in the future i will probably try and modify the harness myself and send Speartech the computer for the reflash. When i got it back i installed it on my engine and test ran it to check for any leaks. It started right up and ran perfectly.
