06-10-2013, 09:18 PM | #1 |
70+ ( Old Skool Club )
Attached antenna
I was removing the old, circa mid 90's, in dash c/d player from my 1972 truck today and the antenna lead wouldn't pull out of the unit. It was attched to the c/d player as I found out when I used pliers to get it out and pooched the antenna lead. Has anyone ever had a c/d player that came with the antenna lead attached? Another thing I discovered is that there isn't a lot a room under the dash of a 1972 Chevy. Does the metal box the C/D sits in just pull out of the hole as I don't see any screws or bolts holding it in.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-11-2013, 09:02 PM | #2 |
Re: Attached antenna
Ive never seen an antenna lead be continual from the head unit all the way to the antenna, did you check further down the line from the head unit for a place they separate?
06-11-2013, 09:07 PM | #3 | |
