#51 |
Re: 76 Crew Cab 4x4 diesel build
Can u take a couple pics of the body. He doesn't need the frame or anything, just the cab. U can text me pics if its easier. 3194642467.
Thanks Brent Posted via Mobile Device |
#52 |
Suburban Hick
![]() Join Date: Aug 2008
I didn't get to take the dodge apart yet due to the weather. Instead I worked on the front suspension on the chevy. I removed the front clip, motor , and transmission that was in it and I removed all the front suspension hangers. I began sandblasting the right frame rail and was making pretty good progress and then got rained out. Hence the blue tarp. This weekend I want to finish sand blasting and get all the holes welded shut. Then to lay out all my new holes for the suspension and drill them. Dad wants it back on wheels by Sunday evening, but we'll see.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
#53 |
Suburban Hick
Been trying to work as dilligently as I can on this. I got all the holes welded shut, ground and the frame rails painted from the cab forward. Got all the holes drilled and the front spring mounts bolted on, and the holes for the left shackle hanger drilled and it bolted on. Wednesday night I'll head down and do the right shackle and put the axle back under it. Next weekend if I get my car put back together this week, I'll start on the engine mounts.
#54 |
6>8 Plugless........
![]() Join Date: Sep 2007
Looking good Mathew! Don't burn that pretty paint fabbing your rngine mounts in!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#55 |
Suburban Hick
I'll try not too. I have an idea for motor mounts combining your idea, but still making them bolt in. Going to see if I can get some pieces made at work.
#56 |
Suburban Hick
Got the front axle put back under the truck last night. No matter how much I measured mad templates and so on, the sides still aren't even. The front spring mounts front to back and top to bottom are perfect, but the rears are a different story. They are a 1/4 inch off from one another and I'm not sure which one is correct if either. On the plus side, I'm going to bring my 78 home this weekend and use it to cross measure everything from and try to get them set right. Also ordered new diy4x shackles tonight along with a hydroboost/clutch pedal assembly. So still chipping away.
