Old 06-11-2013, 07:06 PM   #1
moregrip
moregrip's Avatar
1977 inline 6 vs. california emissions
I should be taking delivery on a 1977 250 inline 6 shortbed stepside here soon.
I know it's not emissions exempt in CA, ......anyone know how clean these motors typically run? from the one engine pic i have it looks like it might be equipped with federal emissions which I believe for that model year was the same as california emissions.
I plan to do all the normal maintenance, plug wires, plugs, oil, filter, fuel filter, air filter, pcv valve, any water or vacuum hoses, etc etc.
If it doesn't pass smog what are the typical culprits? where would you start?
thanks for the help
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-11-2013, 07:13 PM   #2
Ziegelsteinfaust
Re: 1977 inline 6 vs. california emissions
If it doesn't pass rebuild carb even when really warm. Then I would be suspect of the cat if equipped.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-11-2013, 07:24 PM   #3
moregrip
moregrip's Avatar
I believe this is the correct emissions layout:
Old 06-11-2013, 10:23 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Depending on gvwr it may not have a Catalytic converter.
Old 06-12-2013, 12:09 AM   #5
moregrip
moregrip's Avatar
I think he said it did have cat.....
slight change of topic:
how can I tell what state it was originally built for?
Old 06-12-2013, 12:34 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
If the emissions label is on the core support. Not usually but maybe.
Old 06-12-2013, 06:34 AM   #7
D13
D13's Avatar
They also like to suck oil. Clean / replace the PVC and hose just before the test. Assuming it's an integral head 1bbl, make sure the choke kicks off al the way, and check for cracks on the intake portion of the head.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-12-2013, 11:37 AM   #8
moregrip
moregrip's Avatar
thank you, I'll be sure to check into any cracks when she gets here.
Old 06-12-2013, 11:41 AM   #9
moregrip
moregrip's Avatar
check!
