Old 06-11-2013, 08:10 PM   #1
orangek5
orangek5's Avatar
Np205/350TH Transfer Question
I needed to remove my transfer case.
to fix the pivot shifter bolt that broke.
So I'm getting ready to reinstall.
So my question is, does the transfer case have is own lubricant as in do I remove a plug like a diff. cover and pour in fluid or does it get/use transmission fluid from the transmission?
Am I asking the right question?
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 06-11-2013, 09:11 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Np205/350TH Transfer Question
They need their own lube. Remove the higher of the two pipe plugs, and fill with 80/90 gear lube.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-11-2013, 09:23 PM   #3
orangek5
orangek5's Avatar
Thank you.
1970 Jimmy 4x4 IL6
1971 SWB 327ci v8
