Old 06-11-2013, 08:56 PM   #1
Hardesty454
Hardesty454's Avatar
5 Lug conversion kits.
I have a 69 rear end. Will be changing from 6 lug drum to 5 lug disc. Whats so special about the conversion kits I see from a couple different brands?
Cpp has one for $360.
http://www.classicperform.com/Store/...k/6569RACK.htm
Cant I just buy new 5 lug axle shafts for my make/ model axle and buy the disc conversion kit?
axles
http://www.summitracing.com/parts/ms...del/c10-pickup
Rear brake kit
http://www.summitracing.com/parts/wil-140-10094
Or is there something Im missing? Thanks for the help guys.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 06-11-2013, 09:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 5 Lug conversion kits.
Not sure I understand.
You are comparing the CPP drum brake kit to axles and a Wilwood conversion.
Sure you can do either one.
And there are other alternatives to rear discs than Wilwood.
Just trying to understand.
Keith
Convert to disc brakes.
Old 06-11-2013, 09:20 PM   #3
Hardesty454
And there are cheaper alternatives to rear discs than Wilwood.
Sorry if its confusing.
I mean using the CPP axles and the wilwood brake kit, rather than the discs that the CPP kit comes with.
OR
The Moser axle shafts and the Wilwood brake kit.
Are the CPP 5 Lug Conversion kits (the first link; changes the axle shaft from 6 lug to 5 lug and the according drums) special?
This still sounds confusing doesnt it.
Rob
Old 06-11-2013, 09:28 PM   #4
lolife99
lolife99's Avatar
I would definitely buy Moser axles and whatever brake kit you choose.
Moser has been in the Axle business for a LONG long time.
Quality.
Keith
Old 06-11-2013, 09:32 PM   #5
Hardesty454
Quality.
That made more sense to me, but they a decent drop in price from the CPP set. Wasnt sure if it was just because the CPP axles came with the drums or, the CPP kit had something special to them I wasnt seeing.
Thank you!
Rob
Old 06-12-2013, 12:50 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Thank you!
Replacement drums from the local auto parts store run right at $100 a pair after tax here so the $360 cost from CPP for new axles & drums is about the same cost as buying the Moser axles and local purchase new a set of 71-72 drums.
Another option with rear drums is to find a square body C10 with the larger 11-5/32"x2-3/4" rear brake drums for a little better braking and much more common replacement parts. Get the whole backing plate & drum assembly off of it. In addition to a square body these can also come off a G10 or G20 van. I went this route and it cost me less than $25. Mine came from a 92 G20 van.
I cheated a little and have leaf spring rear suspension so I am using a square body rear axle in mine that I had left over from another project. I was able to just pick up a set of common 5-lug C10 axles and the brake drums to match and swapped out the 6-lug axles & drums that came on my 4x4 sourced rear axle. Square body trucks use the same rear end housing for both 2wd and 4x4 so it doubles the gene pool for donor axles when you need parts.
I assume a trailing arm 12-bolt will have the same axle flange to backing plate mount distance as a square body leaf spring 12-bolt. I will find out for sure when I rework the rear brakes on my stepside.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
