Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-09-2013, 10:03 AM   #26
TonyJohnson
TonyJohnson's Avatar
Re: Project "It's a Jimmy Thing"
Nice work. Really smart way to get that shaft cut straight! I need a mentor check... lol. Nobody ever showed me that one. Now I'm realizing it's the way to cut bolts, etc. Now you've got me feeling dumb.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 06-10-2013, 09:15 AM   #27
Wasted Income
Boosted Member
Wasted Income's Avatar
Nice build!!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-10-2013, 10:13 AM   #28
JJH Jimmy
JJH Jimmy's Avatar
Thanks! It was the only way that i could come up with to cut the shaft some what straight with out having to take it back out.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-10-2013, 10:17 AM   #29
JJH Jimmy
JJH Jimmy's Avatar
Originally Posted by Wasted Income View Post
Nice build!!
Thanks! Your blazer build is pretty sweet too. Sorry about the engine. I'm not putting turbos on this one, but i have a 51 5 window that will get them someday. I will be looking for a build thread on your 69.
1985 Chevy K20
1994 GMC Yukon
Old 06-10-2013, 10:25 AM   #30
Wasted Income
Boosted Member
Thanks! I'm watching this build for ideas for the '69
Turbo diesel
Old 06-11-2013, 10:07 AM   #31
JJH Jimmy
JJH Jimmy's Avatar
A few pictures of the fuel lines and fuel pump hanger.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 10:26 AM   #32
JJH Jimmy
JJH Jimmy's Avatar
I installed a Entropy radiator. I called Tony at Entropy and he built me a standard radiator and changed the inlet and outlet pipes to the ls sizes and installed a steam port connection. I liked the standard radiator over their ls swap radiator for a couple of reasons. I could use standard 2003 truck hoses, the tranny cooler is on the passenger side and it made it easier to route the lines and the radiator cap is not hanging right over the battery. I tapped the water pump for the temperature sender like many have done. I also stole an idea from ls1nova71 on this board and cut the battery tray apart and swapped the sides so it essentially made a mirror image of itself and could be mounted on the drivers side. I still need to fit the inner fender to make sure it clears before i blast and paint it.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 10:32 AM   #33
JJH Jimmy
JJH Jimmy's Avatar
More pictures.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 10:39 AM   #34
jaros44sr
jaros44sr's Avatar
Nice build, enjoying the info.
Im getting ready to run fuel lines, and could use some help, info. Did you say they are earles fittings and fuel lines
Are using a tip over vent?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-11-2013, 10:44 AM   #35
JJH Jimmy
JJH Jimmy's Avatar
I stole another idea from crash on this board and mounted the computer under the dash like he did. I also fit the harness to the firewall and mounted the DBW pedal.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 11:12 AM   #36
JJH Jimmy
JJH Jimmy's Avatar
Thanks. No, i am using Swagelok style compression fittings and stainless tube for the main runs and Russell AN fittings and proclassic hose for the flex connection up the back of the engine. You can get a 20' length of tube at a piping supply house for like $20.00 and the fittings are a couple dollars a piece if you get Bilok or Parker brand (SwageLok brand is expensive). They are good for alot of pressure. I have personally used them on high pressure steam and lube oil systems. The hard part is bending the tube. I suck at it. lol. I am using a roll over vent it is in the top of the fuel pump hanger. Let me know if you have any more questions. I would be glad to help.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 12:59 PM   #37
skorpioskorpio
I hope you're being sarcastic, it's like tubing artistry.
skorpioskorpio is offline   Reply With Quote
Old 06-11-2013, 01:01 PM   #38
jaros44sr
jaros44sr's Avatar
Yeah, im familiar with swageloc, used to work for a small company that built cats for diesel engines...cool stuff
Thanks for the info., ill check it out
Your welding skills are impressive, you may be bad at bending ( looks good to me )but, i really suc at welding
Did you buy the roll over vent from someone?
Does the fuel line fray like ss braid?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-11-2013, 02:48 PM   #39
JJH Jimmy
JJH Jimmy's Avatar
Thanks for the compliments!
The roll over vent came with the fuel pump hanger which i got from Tanks Inc. I also got the Walbro pump and level sender from them as well. If i was going to do it again i would either find a pump hanger that was a little higher quality or build my own. I am sure that it will work fine but the flange part that mounts down to the tank is a little thin and flimsy and the lines are just soldered in to it.
I have never used the Russell SS stuff before but i have heard horror stories about it. The proclassic hose is just rubber hose with a fabric braid around it. It will not rub on the frame or other painted surfaces and take paint off. It will fray if you are not careful when you cut it. I wrapped teflon tape around where i was going to make the cut and then i cut through the center of the teflon tape with what i call "reed" cutters. Then took the rest off the teflon tape back off of the hose and installed the ends. The reason i used teflon tape is because it is not sticky so when i pulled it back off it would not unravel the fabric braid. I hope that this makes sense.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 03:24 PM   #40
JJH Jimmy
JJH Jimmy's Avatar
[quote=skorpioskorpio;6118374][QUOTE=JJH Jimmy;6118234] The hard part is bending the tube. I suck at it. lol.
I am not sure about that but it will get the job done. Thanks.
1985 Chevy K20
1994 GMC Yukon
Old 06-11-2013, 04:51 PM   #41
SONOSADSACK
SONOSADSACK's Avatar
Another great build to follow along with. I can’t be the only one here that really appreciates you taking the time to share what you have done but what really helps is explaining what you used. I absolutely hate searching for parts, ideas and or quality vendors/manufactures. Keep it coming. (No details are too small to share either)
SONOSADSACK is offline   Reply With Quote
Old 06-11-2013, 07:55 PM   #42
notsolo
notsolo's Avatar
Really nice build coming together, should be a dream to drive. custom exhaust heat shields look great along with (Everything)...else. Is the silver firewall a teaser of whats to come?...and If your dog is done with the welding coat (Post#4) pass it on..some of us could use it.
notsolo is offline   Reply With Quote
Old 06-12-2013, 12:00 PM   #43
JJH Jimmy
JJH Jimmy's Avatar
Thanks! I have been following along with your build as well. Very nice! I love the green. Thanks for the info on the Entropy radiator by the way. In my opinion it is the only way to go. When we get these things on the road we will have to meet up and go for a cruise around the dunes. Although, i will not be jumping off test hill like some people up there.
I feel like i needed to start this build thread to give back to the site all of the great information that i have gotten from it. I only wish that i would have started a year ago on day one of the build. If anyone has any questions of things that i have done please feel free to ask.
1985 Chevy K20
1994 GMC Yukon
Old 06-12-2013, 12:22 PM   #44
JJH Jimmy
JJH Jimmy's Avatar
Thanks! I am not too much further ahead than the silver firewall on the rotisserie now. I will have the build thread caught up in a couple of weeks then it will start going a lot slower. I worked my butt off last summer on the rust repair and this summer i plan to ride my Harley a little bit more. But, i don't want this to turn into a 10 year project either. I would like to have it real close by next summer. I didn't give the welding jacket to my dog "Harley" she actually grabbed it off of the bench and laid it on the floor to lay on! She is smart. When she doesn't think that she is getting enough attention she will grab the last thing you touched and bring it out into the yard including tools, parts and beer. You wouldn't believe the things i found in the yard after looking in the shop for hours!
1985 Chevy K20
1994 GMC Yukon
Old 06-12-2013, 12:37 PM   #45
jaros44sr
jaros44sr's Avatar
ok, i will have to search for the rollover vent, my 2002 f body fuel pump should be coming in tomorrow
i have plans to use a nickle/copper fuel hard line, should be easier to work with. and thanks for the tip on the teflon tape. im guessing that proclassic is ok to use for FI?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2013, 01:31 PM   #46
JJH Jimmy
JJH Jimmy's Avatar
You may be able to use something like this. I hope the link works.
http://www.tanksinc.com/index.cfm/pa...prod/prd98.htm
The Proclassic hose is rated for 350 psi i believe.
1985 Chevy K20
1994 GMC Yukon
Old 06-12-2013, 02:05 PM   #47
jaros44sr
jaros44sr's Avatar
"tanks" for taking the time, sure looks like it will work....350psi works as well
Seems like your fitting in well around here, invalueable info. provided
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2013, 10:17 PM   #48
SONOSADSACK
That sounds great. I don’t have any plans to ever launch my blazer either. I'm pretty content to sit and watch others beat on their junk.
Who did you get your exhaust pipe from? Was it just a bunch of bends or was it more of a vehicle specific kit or …?
Old 06-13-2013, 10:15 AM   #49
JJH Jimmy
JJH Jimmy's Avatar
The exhaust pipe is 2 1/2" stainless steel sanitary tubing scraps that were left over from a job at work. I also got a few 90 bends as well. I cut the stock manifold flanges off of the down tubes that came with the engine and welded them to the stainless tube and welded stainless oxygen bungs that i got from summit to the tube. I just cut and mitered the fittings for the angles i needed and purge welded everything together. It took for ever to do, but it turned out better than expected. I still have to finish up the exit pieces after i get the body back on. I got the stainless Borla mufflers from a place called Street Side Auto for $65.00 a piece! I used the band clamps from them because i was worried that it would be to loud for my tastes, but after a test run of the engine it sound great. I may take the band clamps off and weld them in as well now.
1985 Chevy K20
1994 GMC Yukon
Old 06-17-2013, 09:56 AM   #50
JJH Jimmy
JJH Jimmy's Avatar
I sent the harness and computer to Speartech. John modified my original harness to stand alone and flashed the computer. Before i sent it out i emailed about six different companies that do this and Speartech was the only one that responded! After i got it back i had a few questions and he has always called me back. I would highly recommend using Speartech. If i do another swap in the future i will probably try and modify the harness myself and send Speartech the computer for the reflash. When i got it back i installed it on my engine and test ran it to check for any leaks. It started right up and ran perfectly.
1985 Chevy K20
1994 GMC Yukon
