Old 06-12-2013, 11:04 PM   #1
cmyc5575
Water temp gauge sensor placement.
I just bought a water temp gauge and have no idea where to install on it on the block. The truck has got one currently on it right now, which is located below and between number 1 and 3 cyclinder.
cmyc5575 is offline   Reply With Quote
Old 06-13-2013, 12:18 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Water temp gauge sensor placement.
if the stock one works you can leave it and put it on the head on other side
a lot do,it's the same spot but closer to the back
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-13-2013, 01:21 AM   #3
cmyc5575
Yeah my stock one doesnt work.
Old 06-14-2013, 12:51 AM   #4
jon75
jon75's Avatar
If the stock one doesn't work, then why would you leave it in the block?
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 06-14-2013, 12:54 AM   #5
cmyc5575
My stock one is not hooked up! The po that i bought it from also bought an aftermarket gauge for it and im thinking that its installed in the wrong area.
Old 06-14-2013, 06:45 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
look on the intake near the water neck or on the water neck, might be a plug you can remove and install there, thats where mine is and works fine
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-14-2013, 07:12 PM   #7
cmyc5575
Ok, thanks. Does this give a pretty acurate reading of the block also?
