06-13-2013, 07:48 PM | #26 |
Old member
Re: need a little help on a tpi swap
You have a few ways to get the gas out of the tank. One is build a small sending unit tank to mount under the truck to the frame. Put a electric pump in line to fill it are gravity feed it. It will also house the pump for the motor and the return line.
The one I like the best is. Take the orignal tank out of the truck and measure the bottom front side of the tank and build a box to weld to it. Mark the tank where the outline of the box. Drill holes into the gas tank and weld a fitting for the fuel line into the new box then weld the box to the tank. Then use a inline high out put pump to the motor with filter on both sides of the pump. Are buy a fuel tank for fuel injection and mount it in the frame.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-24-2013, 07:26 PM | #27 |
ok guys engine and trans are in and moving along now im having an issue with my driveshaft i have a 72" single piece and need a 69" or 70" i was wondering if you know of any gm vehicles that have one or should i just get mine cut
09-24-2013, 08:13 PM | #28 |
Get it cut, they will balance it and all.
Post some serious pics when you are done. I have two 87 IROC's and was thinking about taking one of the TPI's out for my sons 75 stepper.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
09-24-2013, 08:48 PM | #29 |
Old member
I'm fixing to have a complete combo 305 HO TPI/700R4 took out of my 71 to be replaced with a 6.0 LSx. If anybody is intersted PM me. Complete Street & performance wiring harness 4 wires and it's running.
09-24-2013, 08:51 PM | #30 |
check out my build thread in my sig, I have converted my 86 C10 to TPI.
09-25-2013, 07:08 AM | #31 |
I did not see the photos well earlier. I would not use those brass unions, especially on the pressure side. Those gas unions are made for 4-5 psi and are being used at over 40 and even higher at times. You are much better off to use hydraulic unions that are rated for high pressure. You do not want leaking pressurized fuel.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-25-2013, 08:04 PM | #32 | |
Kill Bill...et
10-07-2013, 10:59 PM | #33 | |
10-07-2013, 11:30 PM | #34 | |
The Older Generation
Yes, on the intake side LockDoc
10-08-2013, 08:30 AM | #35 |
Has anyone used a "T" with sucess on a TPI? I tried that once on a carb motor swap in an old Jeep with an electric fuel pump and had too much air in the system. I had to add a return to the tank to make it work. Some of the late LS stuff has a filter that is a return, so I guess if you had a check valve in the right place it could work. Just curious if anybody has one running on a TPI swap?
10-08-2013, 09:38 AM | #36 | |
I don't have mine running yet. There would be a lot of difference between a 7psi carbed setup and a 45 psi injected setup. I can't see it getting any air in the injected system. I also don't know why you would need a check valve since there would be no back pressure on the return line. LockDoc
10-08-2013, 01:33 PM | #37 | |
I do not see any big advantage to this method anyway. Why not just return to tank? That keeps the hot returned fuel circulating and will result in cooler denser fuel that should result in more power and longer pump life. I hope it works. I am still curious if anybody has one running with this setup.
10-08-2013, 10:37 PM | #38 |
My TPI has a shrader valve on the passenger side fuel rail, couldnt you bleed off any air with that valve. Seems like it would be the high spot in the system
10-09-2013, 03:26 AM | #39 |
Still plays with trucks
If you put the engine in the forward mount holes it can use the 72" driveshaft but I would have the driveshaft shortened and keep the engine set back in the rear mount holes for a little better weight distribution and more room up front for the accessory drive.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
10-09-2013, 07:40 AM | #40 | |
1-fuel either by gravity or with another low pressure pump is fed to the suction side of a high pressure pump. This pump is below tank level so it should have no air trapped at the inlet. 2-pressurized fuel is pumped to the rail and to the injectors where some of it is returned at the fuel pressure regulator between the 2 banks. This is how pressure is maintained, by returning extra fuel. The schrader valve on the rail is a way to see how much fuel pressure the injectors are seeing. You can't bleed the line past the regulator with this port. 3-returned fuel is generally dumped back to tank where it mixes with all the remaining fuel in the tank. The act of pumping heats the fuel some due to friction and pressure. So returning fuel to the tank allows the tank itself and remaining fuel to act as a cooler. 4-the cycle repeats. If you "T" into the suction side before the pump, you will have a hard time bleeding the system because you are pumping a fuel and air mixture under some pressure until the return line is completely full of fuel with no air. This mixture is under more pressure than the gravity feed from tank so therefore no fresh fuel will be able to take the place of the trapped air. That is what I think will happen. This is what did happen on the Jeep I described. I could be wrong. As I said, I know that some late LS Corvette setups do not use a return line and do return through the fuel filter BUT the LS setup is returning after the pump so it is never trying to pump air. I have never heard of anyone trying this with a TPI and I still think that the fuel has to be hotter because of it. Anybody out there with a running TPI that is using a "T" in the fuel system?
10-09-2013, 12:58 PM | #41 |
Sorry didnt read enough of the thread... I have a 2000 camero intank pump, but my tank is under bed, so no help here.
Guess well just have to wait till Lockdoc gets his running to see if it works
10-09-2013, 01:47 PM | #42 |
For my TBI MegaSquirt build, I put an in-tank pump I had from my old '94 Z-71 pickup, and grafted it onto the original sender pickup. I should have noted how much of the original pickup tube I trimmed, but it's pretty self explanatory. I also put in a return nipple to the top of the sender for the return line. Check out the attached pics to see how it worked. You'll notice the copper return line that's brazed to the brass nipple that serves as the fuel return. It's not pretty, but it doesn't leak and I've got good consistent pressure.
I did have to notch the top of the fuel tank where the sender goes in to allow the pump to slip inside. You have to rotate the assembly a couple of times while putting it in, but if I was able to sort it out, I'm sure anyone can. I heard all sorts of warnings and blatherings about how using an in-tank pump wouldn't work in an unbaffled, unsumped tank. How it will suck air and cause no end of drivability issues. Well, I've got about 3k miles on this setup with the MegaSquirt ECU, and other than a cracked head on my inline 250 (not the fault of the pump I assure you), The drivability has been great, and I've never noticed any issues at a nearly empty tank. So if you're on a budget, I would not hesitate to try this option. Good luck! Shawn
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
10-09-2013, 02:18 PM | #43 |
I agree. A baffle helps but is definitely not required. Contrary to popular beliefs, '82 Corvette tanks are not baffled (the first electronic fuel injected small block). I have done at least 2 fuel injection swaps using unbaffled tanks with no issues at all. They just keep at least 1/4 tank and neither has any issues with at least 20K miles between them.
10-09-2013, 06:55 PM | #44 |
Subscribed
10-09-2013, 07:56 PM | #45 |
I am also swapping in a TPI and have read as much as possible hear and other places. One write-up I saw was concerning the return line back to the tank. The guy didn't put the return line all the way down to the bottom of the tank, sort of had it dumping in at the top. The issue was the fuel got aerated and he had some hesitation issues because of air in the fuel going into the pump until he figured out what was going on. Anyway I thought it was a good tip. Here is a good site for general TPI info:
http://www.chevythunder.com/
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
10-09-2013, 10:22 PM | #46 | |
That may be a while. I have to finish the '70 Chevy 4x4, the '34 Ford, and the '36 Ford before I start on the '70 swb again. I am close on the 4x4 and the '34 but I have quite a bit left to do on the '36. LockDoc
10-10-2013, 10:05 AM | #47 |
I have always liked the looks of the L98 TPI mills. I had one in a 90 Corvette. It had so much grunt down low. It always seemed to me that it would have been a better truck engine than sports car engine.
Great gas mileage, reliability, reasonable performance, and sweet looks are just a few of its assets. I have thought about putting one in my pickup but never did. Please post pics of yours as you go along. I'm betting it will be a great ride.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
10-10-2013, 11:36 AM | #48 | |
Heres mine in its present state 20131010_113914 by jarosaj, on Flickr 20130804_083211 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-10-2013 at 11:51 AM. |
10-12-2013, 03:54 PM | #49 |
this is my fuel pump and filter combo im using my stock tank will upload a pic of my sending unit once its done. its a walbro inline pump 60psi max($112 from summit) and a stock replacement filter for my camaro which is a 10 micron($15 from autozone)
10-13-2013, 04:39 PM | #50 |
Interesting thread. I've ordered a F.I.R.S.T TPI system and hopefully will it will be delivered in the next couple of weeks. It's going to sit on top of my ZZ4. This set up is pretty much a factory TPI system on steroids.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
