LS turbo mounting-f body manifolds?
Looking for some examples of how people installed their turbos.
From some of the pictures I've seen here and on other sites, it looks like some have flipped the fbody/truck manifolds to work. I have a 5.3 with manifolds from a 2000 firebird formula and am looking to mount a single turbo. I'd like to keep the factory AC compressor in the same place as well. If anyone has any pictures of their setup, or some advice on how they mounted their turbo, feel free to share. Thanks! |
Boosted Member
Re: LS turbo mounting-f body manifolds?
I've built several different turbo setups for these trucks. First setup was with homemade logs, second was with LS2 GTO manifolds, and the most current setup is with one C6 vette manifold, and one truck manifold.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Wow, that is BEAUTIFUL work.
Those pictures are worth 1000 words, so thanks. Did you prefer the C6 manifold for a better angle for piping? Love the wastegate dump so it sounds like the gateway to hell is opening under full boost ![]() |
Boosted Member
Thanks.
I had two vette manifolds, but the DS would not clear the master cylinder. ![]() ![]() I went with the C6 manifold on the PS to give clearance for the high mounted AC compressor. ![]() ![]()
Wasted income, not to change subject but it looks like you have a sanden sd7 compressor. What bracket are you using?
Posted via Mobile Device |
Boosted Member
It's a custom hybrid setup from a guy on LS1tech. Expensive, but worth it to tuck the compressor in tight to the engine up high.
What kind of boost levels will you be running? I'm not really sure if I NEED an intercooler.
#8 | |
meowMEOWmeowMEOW
The only cars that really don't run an intercooler these days are strip only cars that don't have to deal with issues of heat soak, or the even smaller portion of cars running "Chemical cooling" like running a methanol setup or or cooling the charge with nitrous.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#9 | |
Boosted Member
Just asking, because you are spreading half-truths. I have no A2A or A2W and my setup runs nice. I have no problem getting IATs below ambient with my water/meth setup ![]()
#10 | |
meowMEOWmeowMEOW
Its not a half-truth, its a full opinion. Carrying around an extra bottle of meth gets old, been there. I also don't like the idea that if I do runout (road trip, whatever), I lose the ability to make full use of the vehicle, or risk det. Even when I had a diablosport (different ride) and could switch back and forth off the meth tune quickly, it was still annoying. Meth works fine, but I still hold that carrying another tank of a consumeable product isn't really suited for a lot of people. You can cool an intake charge with nitrous of co2 also, but it doesn't really mean that its the best option for a street car. Its just one more thing to worry about. In most cases there is no reason NOT to run an I/c, aside from space, which is these trucks is not the concern like on some vehicles. I'm all for it in addition to an I/c but I just don't feel its the right option for a lot of people on a street car. It doesn't mean your car doesn't work, or that it doesn't run nice....people need to stop assuming that because a person doesn't favor a setup, its not a damn personal affront to anyone running it.
I've been looking into a turbo for my project too. (once it's finally done of coarse!) I wonder if anybody has ever tried a trick performance or kb racing kit?
I know the truck manifolds don't fit very well to start with, but there are some members who have made them work by trimming the frame slightly. I guess the other concern would be routing the crossover under the transmission. It might be a little low with a 4/6 drop or more. Any thoughts on these setups?
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
#12 | ||
Boosted Member
Ok....that made me lol.
![]() Quote:
I challenge you to find me a spot to mount a FMIC between the radiator and grille. ![]() Also my 100% opinion ![]() Quote:
meowMEOWmeowMEOW
^^^which kit are you running? I ran a snow kit and even on my little SRT I burned through more than a gallon of meth a week.
JDM yo. ![]()
Haha shoulda kept the STi intercooler off of my old car
![]() I've seen where people put the intercooler between the radiator support and the grille, but it does look like a tight fit, and you have to drill a big hole in the core support.
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
#15 |
Boosted Member
It's a hybrid Snow/Devils Own kit that I put together. It's controlled by the Megasquirt to enable at 4 psi and progressively ramp up with boost.
Nice top mount.
#16 |
meowMEOWmeowMEOW
I got some questions on that setup but I'm moving it to PM to keep this thread clean.
#17 |
By all means, keep them in here if you want, I'm trying to see what the best route is. I'm at the crossroads right now.
#18 |
hooker ls swap manifolds
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#19 | |
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
