Old 06-17-2013, 12:58 PM   #1
Claytona08
Claytona08's Avatar
Sooo Confused
I ordered a DJM lowering kit week before last and decided to install it this weekend. The first thing it tells you is to check all measurements prior to installing the kit. When measuring I noticed the front passenger side was 1/2" higher than the front driver side (See pic below). I didn't think much of it as I thought the spring just didn't settle the same as the other. After installing the kit now the front passenger side is 3/4" higher than the front driver side. After scratching my head all day yesterday I noticed something that I thought was weird! I don't think the cab is sitting level on the frame or something. (See pic below) I hadn't had a chance to climb under it yet to see because I just noticed this in pictures I was looking through here at work. Any suggestions on what might be the problem?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 06-17-2013, 01:21 PM   #2
1slo_camaro
Re: Sooo Confused
im not an expert by any means. but id say your cab mount on the driver side is shot.
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 06-17-2013, 01:26 PM   #3
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Ahhh you could be right. I just looked back at the picture and the body line from the cab to the bed on the driver side is not lined up. It looks to be approx. 1/2" off
Old 06-17-2013, 01:27 PM   #4
tex_waco_usmc
Project Heaven in my 67!!!
Re: Sooo Confused
You say that, but I just installed new mounts on my 86 and it looks the same!
tex_waco_usmc is offline   Reply With Quote
Old 06-17-2013, 01:31 PM   #5
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Dang that sucks!!!! I worked for an hour turning the springs under the truck trying to even the front end out....no luck
Old 06-17-2013, 01:34 PM   #6
tex_waco_usmc
Re: Sooo Confused
Im hoping someone else has a suggestion that might help us both out. But currently mine sits just like yours and I have new body mounts under my body.
Old 06-17-2013, 01:44 PM   #7
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Let's keep our fingers crossed!
Old 06-17-2013, 01:44 PM   #8
bigwheel15
bigwheel15's Avatar
Re: Sooo Confused
If you replace the mounts and its still off I believe you can shim the cab mounts.
bigwheel15 is offline   Reply With Quote
Old 06-17-2013, 02:27 PM   #9
Rich84
Rich84's Avatar
Re: Sooo Confused
Trying to get these trucks level is a real pain in the butt..I would think in your case you would have no choice but to shim the cab mount. Make sure that nothing is wrong with the bed mount first.
Rich84 is offline   Reply With Quote
Old 06-17-2013, 02:42 PM   #10
tex_waco_usmc
Re: Sooo Confused
Isnt the bed mount just a bolt through the frame, with a small (1/8") spacer in between the bed and frame rail?
Old 06-17-2013, 03:03 PM   #11
DREAMER1
DREAMER1's Avatar
Re: Sooo Confused
Personally I'd start off by crawling under it and measuring the bottom of the cab to the top of the frame. Right beside all 4 cab mounts. And compare the measurements. Adjusting the bed is easy, but make sure your cab is level first is what I'm sayin
DREAMER1 is offline   Reply With Quote
Old 06-17-2013, 03:06 PM   #12
vegadesign
vegadesign's Avatar
Re: Sooo Confused
sounds like a case of that famous chevy tilt
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 06-17-2013, 03:41 PM   #13
DREAMER1
DREAMER1's Avatar
Re: Sooo Confused
^^^x2
Old 06-17-2013, 04:17 PM   #14
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Yeah that sounds like the place to start.
Old 06-19-2013, 11:05 PM   #15
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Sooo Confused
Before you go crazy with the cab mounts, check the rear springs. After I dropped my truck, it leaned hardcore to the driver's side. It was a bad case of Chevy lean. This comes from many decades of the driver and the gas tank on the same side, with nothing as heavy on the other side. I swapped my leafs in the rear from side to side and it's not noticeable now at all.
I don't know if you can tell from the pics, but this is before the leaf swap. If you look at the front fender bottom to tire gap on the driver's side and the passenger side, you can see it's sitting higher on the passenger side. After the swap, it's pretty much even.
Last edited by killthewabbit; 06-19-2013 at 11:07 PM. Reason: Forgot the image tag
killthewabbit is offline   Reply With Quote
Old 06-20-2013, 09:06 AM   #16
Claytona08
Claytona08's Avatar
Re: Sooo Confused
The dimensions were off on the front passenger wheel prior to installing the drop. I'll check everything I can once I have time. The front and passenger side back measure out the exact same. Hey man, I used your truck as a template for the tire size on my truck! Got my wheels and tires ordered early this week. Glad you posted the pics of your truck.
Old 06-20-2013, 02:28 PM   #17
killthewabbit
Re: Sooo Confused
Good deal, man. Hope you like them as much as I do. I'm pretty happy about how it turned out and how the drop and wheels/tires are holding up. I drive it every day, and it sees a fair amount of potholes and otherwise crappy roads.
I still crack up when I think about you negotiating the purchase of your truck with the old dude outside in his tighty whiteys.
Old 06-20-2013, 03:16 PM   #18
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Ouchhh, I tried to wipe those thoughts away from my memory...lol...Thanks
This truck won't be my daily driver so I am sure I will be more than happy with it. I plan on making it my "Drive to Work on Friday" vehicle.
Old 06-20-2013, 03:42 PM   #19
cmyc5575
Re: Sooo Confused
Try flipping the leaves from the driver side to the ps and same with the springs. I had this same issue on my 82 lwb before I sold it.
cmyc5575 is offline   Reply With Quote
Old 06-21-2013, 08:22 AM   #20
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Ok so I climbed under the truck yesterday (Finally) and this is what I found. Now remember that the truck was sitting a 1/2" unlevel prior to installing the drop kit. The a-arms are closer on the driver side than they are on the passenger side. Approx. 1/2"
Old 06-21-2013, 10:41 AM   #21
tex_waco_usmc
Re: Sooo Confused
Are those stock springs or aftermarket?
Old 06-21-2013, 11:17 AM   #22
Claytona08
Claytona08's Avatar
Re: Sooo Confused
Aftermarket springs that came with the kit.
Old 06-21-2013, 12:08 PM   #23
tex_waco_usmc
Re: Sooo Confused
I'd start looking at spring height between the two springs and maybe a-arm bushings!
Old 06-21-2013, 12:13 PM   #24
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Sooo Confused
Swap the springs up front. Or turn one in the bucket
Old 06-21-2013, 12:27 PM   #25
Rich84
Rich84's Avatar
Re: Sooo Confused
I have the same exact issue with the old springs and the brand new springs..
