Old 06-17-2013, 04:14 PM   #1
chris1htx
Recharge Hose
Has anybody ever used this recharge hose or something similar? I'm trying to avoid going to a mechanic and paying an arm and a leg to get my a/c recharged. Do you know if you would need that vacuum system to get the freon out?
chris1htx is offline   Reply With Quote
Old 06-17-2013, 10:25 PM   #2
JellyBeanDriver
Re: Recharge Hose
That will not attached to R12 service ports. Is your system already R134A converted?
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 06-17-2013, 10:31 PM   #3
chris1htx
Re: Recharge Hose
Yeah it's already converted.
Old 06-20-2013, 11:52 PM   #4
JellyBeanDriver
Re: Recharge Hose
You only need to vacuum the system out if you have opened it up or the charge in there has gone to zero. If zero though you should fix the leak, which means opening it up and now you need to vacuum.
If you're topping up, no need to vacuum.
That said, R134A is not as forgiving to under and overcharge. For systems from the factory as R134a, it is recommended to evacuate the system and charge by weight.
