11-26-2003, 11:15 PM | #1 |
Old member
For you Baggers
I like this set up. I could build something like that if I had plenty of money, and tools.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-26-2003, 11:59 PM | #2 |
My Thoughts Exactly!
Nothing special about it...it's just a glorified 2-link setup. Which isn't the best setup anyway. it's not too hard to make a setup like that for a leaf spring truck in the first place.
11-27-2003, 12:06 AM | #3 |
Project92 SWB stepside
It looks like a triangulated 4 link to me!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
11-27-2003, 01:43 AM | #4 |
2ND...... TRIANGULATED 4 LINK
11-27-2003, 02:56 AM | #5 |
THE QUICKER FIXERUPER
I say tri 4 too, we don't want to get started on 2-links again
11-27-2003, 03:09 AM | #6 |
I like it. How hard would it be to fabricate something like that from scratch?
11-27-2003, 12:48 PM | #7 |
It's pretty straight forward to do. Go to www.***************** He has everything you need.
11-27-2003, 08:11 PM | #8 |
aka Crusher, Crushergmc
Nothing "glorified" about that. It's real nice. I wonder about bag placement on it. That seems like alot of leverage. It would cut down the load capacity of the truck. I want to be able to pull a good sized trailer.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
11-27-2003, 09:30 PM | #9 | |
Either way it's a ridiculous setup. there are much beter cantilever style setups to be had. |
11-28-2003, 07:05 PM | #10 |
Old member
Set up
I didn't mean that it was the best out there, just saw it and thought it was nice set up. If you do reseach on baggs they tell you the front mount is for looks and the further back you place your baggs are for load, so which do you think he was going for. I would say look.
11-28-2003, 10:25 PM | #11 | |
Re: Set up
11-29-2003, 03:19 PM | #12 | |
11-29-2003, 10:31 PM | #13 |
FUEL CELL GURU
Definately....
4-link. If the rear lower mounts were solidly mounted, the upper links would be useless not to mention it would put the suspension in a bind. Used this setup on two customers trucks before. Plenty of lift and comfortable ride. Looks good to me. Later, FuelCellGuy
11-29-2003, 11:19 PM | #14 |
I agree with FuelCellGuy. It is a 4 link. If the lower bars didn't pivot at the axle tubes, the suspension wouldn't travel much from where you see it. Also it does look like he would get tons of lift with where the bags are mounted. Later
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album Last edited by Injected68LS1; 12-26-2003 at 04:22 AM. |
11-30-2003, 02:43 AM | #15 |
Its kinds like getting to the center of a tootsie roll pop. You will never know!! Any one have a pic of the mount to the rear??
11-30-2003, 04:25 AM | #16 | |
Old member
Re: Definately....
12-25-2003, 02:49 PM | #17 |
Progress = 0%
here is the rest of the truck that is shown in that first picture......
http://www.cardomain.com/memberpage/247814
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
12-25-2003, 02:57 PM | #18 |
Wow thats alot of lift!!
12-26-2003, 12:17 AM | #19 |
Looks great to me. If you go check out the pics on cardomain you can see it hits sides well an has a ton of lift. I wonder what it looks like behind the tire. I'd like to see a pic of the joints.
2004 Chevy Silverado 1500 RCSB 4.8v8 5 speed 2002 GMC Sierra 1500 RCSB 4.8v8 auto (wifes truck) 1986 Chevy Caprice 5.0 auto (like driving a couch down the road) 1982 Chevy C30 Crew Cab 2wd LWB - Beater Truck (I have more!) Too many to list! |
12-26-2003, 04:24 AM | #20 |
Andy4639,
I don't agree with you. The lower bars can not be mounted solidly to the axle tubes. They have to have a pivot here to move at all. It's basic engineering linkage design. It's a 4 link with a pivot at the end of each bar(including the axle tube). If it didn't have a pivot there the suspension would be a triangulated truss(that's from engineering STATICS class, meaning things that don't move). Statics explains how bridges are made. It would be very stong and not move an inch. I could draw a picture if you would like. Injected
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album Last edited by Injected68LS1; 12-26-2003 at 04:29 AM. |
