Old 06-19-2013, 08:01 PM   #1
DallasTxImpalaSS
DallasTxImpalaSS's Avatar
Radiator
What radiator are you guys running? I have a 91 R3500 with the 454 tbi. I need to replace my radiator, I was looking at the Be-cool qualifier or the Summit aluminum universal. But Ican not find any that match the dimensionsof the radiator I have now. The biggest I can find is 31x19. I was curious what replacement radiators some big block guys are using.
1991 GMC R3500
DallasTxImpalaSS is offline   Reply With Quote
Old 06-19-2013, 09:28 PM   #2
tucsonjwt
Re: Radiator
I am using a ReadyRad stock radiator replacement for my 83 C20 454, granny 4 spd, factory A/C. I did have one very small leak which I had to have repaired about 1 year after I put it in, but other than that it has worked well in 110 degree desert heat. Even the few times I have loaded it down to the max it did not overheat. It is only two cores but it appears thicker than the other 2 core radiators I have seen for small blocks. I think I paid about $130 for it about 4 years ago. The factory temp gauge reads less than 160 degrees when it is completely warmed up - the gauge could be off but it does function.
Others here seem to like Griffin aluminum radiators, but I lost interest in aluminum radiators after my bad experience with one in my 1963 SWC Corvette when I was still a pup about 45 years ago. I like copper/brass.
tucsonjwt is offline   Reply With Quote
Old 07-03-2013, 03:56 PM   #3
DallasTxImpalaSS
Re: Radiator
I had been looking at the Griffin, but it only has 2 rows. I was curious how the aluminum 2 rows cool compared to the copper 4 rows. Any thought on that
1991 GMC R3500
Old 07-03-2013, 05:06 PM   #4
MalibuSSwagon
Re: Radiator
I have a Spectra Premium stock replacement, aluminum core with plastic tanks. Never an issue with cooling or failure, I've used this brand on several vehicles.
MalibuSSwagon is offline   Reply With Quote
Old 07-03-2013, 10:32 PM   #5
JellyBeanDriver
Re: Radiator
FWIW, I am very soon going to put in a aluminum core/plastic tank 2 core Spectra Premium in our 86' C30. She runs warmer on hills when towing the trailer. It's got a Ready Rad 4 core in there now but the cores are small, lots of solder slag inside when I peer inside, and the number of tube rows isn't great. I don't think it's a very well 'engineered' 4-core.
Aluminum core radiators use much wider tubes, like 1". 4-core brass/copper the tubes are much smaller, like 3/8".
From what I've read a 2 core aluminum is at least as good as a 4-core brass/copper if not better.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 07-04-2013, 10:20 AM   #6
SCOTI
SCOTI's Avatar
Re: Radiator
A replacement radiator from your local Oreilly's will get the job done & be much easier to deal w/if you have issues in the future.
I bought one from an internet company for my 74 & it eventually started leaking. It was low cost but after a few years started leaking the cost to repair was close to the cost of purchase. Couldn't find a receipt so they wouldn't honor the 'lifetime' warranty to replace it @ no cost. Purchased another/replacement @ Oreilly's. It was OE quality so I got the one for my BBC in my dually there as well. It's a traditional brass 4-row & huge....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
