Old 06-20-2013, 09:45 AM   #26
Keith Seymore
Keith Seymore's Avatar
Re: Short Wide Drops, bring em all...
Originally Posted by J Knight View Post
Keith, would there be any weakening in the hanger if you trimmed off a couple of inches from the top to get a full 4in drop? Im thinking it would be fine.
For which hanger? For the front - all that material above the frame can be trimmed as an appearance improvement.
For the rear hanger - I don't think I'd go much lower than that last production hole (the lowest one) in the hanger.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-20-2013, 11:20 AM   #27
riz
Originally Posted by killthewabbit View Post
My lowering kit was 2.5" spindles and 2" springs front and a flip kit for the rear. Everything's from McGaughy's. Here's a link to the kit:
http://www.mcgaughystore.com/mcgaugh...it-part-93150/
The front dropped a bit more than advertised, but the fender bottom just covers the tires, which is where I wanted it. I also had to swap the rear leafs side to side because the standard issue square body gas tank lean was very pronounced at this height.
That's the exact stance and kit I want to use. How was it to install? Any problems/issues?
RIZ
riz is offline   Reply With Quote
Old 06-20-2013, 02:23 PM   #28
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
It went in pretty easy. I cut off the factory bumpstops and had enough clearance that I felt it unnecessary to install the C-notch. I had a nasty lean to the driver side when I finished (that was likely there before, but not as noticeable), so I swapped the rear leafs side to side. Since then it's been great. It's been my daily for almost two years, and dropped for a year and a half.
killthewabbit is offline   Reply With Quote
Old 06-20-2013, 11:36 PM   #29
bryan76
5/7 belltech flip rear with lowering leafs 2.5 drop spindles 3" springs
bryan76 is offline   Reply With Quote
Old 06-21-2013, 10:17 AM   #30
77c10
77c10's Avatar
Mine has a very pronouced lean to the passenger side in the rear only. I may try swapping my leafs to see if it cures it.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 06-21-2013, 10:19 AM   #31
77c10
77c10's Avatar
Originally Posted by Desperado454 View Post
3" spindles, 2" coils, axle flipped and a 2" channel.
Is that a front bumper moved to the rear?
Old 06-21-2013, 10:25 AM   #32
osaltyone
osaltyone's Avatar
Porterbuilt front KP rear
osaltyone is offline   Reply With Quote
Old 06-21-2013, 11:21 AM   #33
cyclefreak207
cyclefreak207's Avatar
Sexyyyyy truck. I want bags, but since my trucks my daily, and I just had to put another motor in I don't have the funds for a bag setup, or the time to have it torn apart...
86 Short Bed Build
I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment!
cyclefreak207 is offline   Reply With Quote
Old 06-21-2013, 01:10 PM   #34
Desperado454
Desperado454's Avatar
Yeah, I was desperate to have something to fill the void, and a front bumper was all I had. Still looking for a proper rear bumper though.
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 06-21-2013, 02:01 PM   #35
87r10owner
Here's another shot
87r10owner is offline   Reply With Quote
Old 06-21-2013, 05:50 PM   #36
killthewabbit
Bet it does. Can't beat the price, either.
Old 06-21-2013, 05:51 PM   #37
Low_Life86
Low_Life86's Avatar
6 inch drop up front with flip kit and one leaf removed from the rear
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
