Old 06-20-2013, 01:26 PM   #1
BigElittleg64
BigElittleg64's Avatar
Need help on Front end swap
Put 87 front crossmember and running gear on 64 c10 1/2 ton also installed PS conversion Kit however the pit arm hits lower A arm and Tie rod ends need extending any thoughts or parts numbers would help Thanks
BigElittleg64 is offline   Reply With Quote
Old 06-21-2013, 12:40 AM   #2
Captainfab
60-66 Nut
Re: Need help on Front end swap
If your pitman arm is hitting the lower A arm, you definitely have something out of wack. What steering linkage are you using? The '87 or the '64? I always recommend using the entire later model steering linkage. You will have to locate and drill new holes for the later model idler arm, but this simplifies the steering linkage issue. Plus that way, when you need to replace a part of it, there is no guessing what application you need to ask for.
Here is my favorite thread on a front disc brake conversion:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
There are a few others located in the '60-'66 FAQ index at the top of the main page.
Old 06-21-2013, 10:23 AM   #3
BigElittleg64
Im using the steering linkage, crossmember,a arms, steering gear box from the 87. I have the conversion plates for the PS gear box and if I put the 87 pit arm on it the end hits the lower a arm. Dont know where to go from here.
Old 06-21-2013, 03:39 PM   #4
BigElittleg64
Does any one know if a pit arm off a van or an S10 would fit the PS gear box and fix the lenght issue?
Old 06-21-2013, 04:03 PM   #5
sickboy_1456
Do you have any pics of where it's hitting? I just helped my buddy install all the steering components from an 87 onto his 66. No issues. Like Captain said above, we just had to drill new holes for the idler arm. I'm wondering if maybe the steering box is mounted too low or something?
sickboy_1456 is offline   Reply With Quote
Old 06-21-2013, 04:56 PM   #6
62-One-Ton
62-One-Ton's Avatar
Yeah seems really odd. My 87 crossmember on my 62 frame has no issuses. My center link is close to the crossmember during the turning stroke but no where neqr touching at the pitman arm. I am using the stock 62 box and pitman though.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-22-2013, 12:40 AM   #7
Captainfab
60-66 Nut
If your '87 truck pitman arm is hitting the lower control arm, your steering box is not located correctly. A pitman arm from a Van or S10 will not work. I have always used a '73-'87 steering box and pitman arm, and never had an interference issue if the box is located correctly.
Old 06-25-2013, 03:45 PM   #8
BigElittleg64
Good to know thanks for the info I did some adjusting and it seams to be ok now on to body work and rear diff. Will get some pics as soon as i can Thanks for all the help.
