06-21-2013, 03:55 PM | #1 |
solution to mustang gas tank issues
I found this and thought other people may be interested. note that the sender is on the top. and there is a selection of senders in different ohm ranges. the filler is also removable. kinda pricy though
http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm Mark |
06-22-2013, 03:37 PM | #2 |
Re: solution to mustang gas tank issues
ya it pricey but so are alum fuel cells
06-22-2013, 04:41 PM | #3 |
The best part is the adaptability.
06-22-2013, 08:35 PM | #4 |
Doesn't strike me as pricey at all. Just over $200, what's new that's cheaper?
Yeah, 16 gallons isn't a lot and it makes you put the filler in the bed - I don't mind but I know some will. I had considered the Mustang tank before but thought you could only use a Ford sender so that wouldn't support my original gauge. At only 7-1/2" deep it'll be almost invisible once installed. |
06-24-2013, 10:37 AM | #5 | |
Another bonus id that the dimensions for the mounting flange is right there. For me that works I can make removable mounting frame. and paint it later. I am trying to get all my mounting tabs Etc. done so I can paint the frame. |
