Old 06-21-2013, 03:01 AM   #26
WIDESIDE72
WIDESIDE72's Avatar
Re: cutting holes for factory AC vents
I used a milwaukee 1/2" drill with a handle that screws into the side co five better control. It didnt walk around because the drill bit keeps it centered. Drill the pilot hole first without the saw on the mandrel to avoid it grabbing when you drill through. I considered using my greenlee knockout set but the mandrel wasnt deep enough. I have a lot of cool tools that serve double duty being an electrician!
WIDESIDE72 is offline   Reply With Quote
Old 06-21-2013, 10:57 AM   #27
rcrahn
rcrahn's Avatar
Originally Posted by Toxic Orange View Post
Fantastic! When I cut mine (painted already mind you) I almost had a heart attack when I thought I cut them too big. It's a wirerd shaped hole that will fool you visually. Great job!
LOL!!! Thanks....
I would have been scared too using a sawzall. The HF tool for $18 did the job...
I took my time and did the final fir with a die grinder and hand files.
Originally Posted by da-burb View Post
by the way, is the RH side a mirror image of the LH? If it is I will leave my pdf alone. If you had to adjust it some I will do a tracing of the RH side and scan it to pdf so it will be correct.
Yes, it worked fine....BTW....that Lemans looks cool...
I love it! Down the road I'd like to find a 64 Lemans vert and drop an LSx with 6 speed. Clean up the body with all trim shaved off. Lower it and ride on ride tech suspension.
Lastly, what's that funny white stuff all over the ground? Do you drive your vert around in that?
Originally Posted by mrein3 View Post
I'm kinda late to this party. FWIW, I used a hole saw to cut those side vents. You need to figure out where the center is, make a pilot hole, then cut with the hole saw plunging it straight at the dash. I could tell you the size of the hole saw I used but I'm in Paris and the saw is in my shop in Minnesota.
I used a 1/2" drill and took my time as there is a lot of torque cutting that hole with the contour of the metal.
I'm sure it was like a 3 1/2" saw. That had to be tough. Have fun in Paris. I'll be there in September visiting the Louvre. Watching a video series by The Great Courses to familiarize myself. So much to see....impossible to do in one trip...
rcrahn is offline   Reply With Quote
Old 06-21-2013, 03:59 PM   #28
mrein3
mrein3's Avatar
Originally Posted by rcrahn View Post
...snip...
I'm pretty sure it is a 3-1/2 incher. I'm headed home tomorrow. If I'm not comatose when I get home I'll check the size.
I did the Louvre and Orsay today. No way could you see it all in a week. Look in to a Paris Museum Pass. I got a two day job for around 40 Euros. Also look into getting a navigo pass for the metro and RER. You don't want to drive here and the rails are pretty reliable.
Its looking like I'll be back in September too. I'm not a big city guy and this is a big city.
One or two more of us here in September and we'll have to plan a truck meet.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-21-2013, 06:56 PM   #29
rcrahn
rcrahn's Avatar
OMG...Louvre and Orsay in 1 day...Did you sprint through? LOL...
Yeah, we are gonna ride there from London on the Chunnel and spend 1-2 days just at the Louvre...My wife paints watercolors and chinese brush paintings, so she'll be in heaven...
Can you imagine our trucks in Paris? That would be a gas...
Old 06-21-2013, 09:18 PM   #30
BigRed76
BigRed76's Avatar
The Vintage Air diagram is for their smaller vents, not original AC vents. If you send me your email address I will trace it, scan it, and email you a copy.
If you still have it saved would you wanna email a copy to me? I need to do the same thing here shortly.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-21-2013, 09:37 PM   #31
TazmanB
TazmanB's Avatar
If you still have the pdf template I would like to have it also since I will be adding air to my cab in about a month.
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 06-21-2013, 11:46 PM   #32
rcrahn
rcrahn's Avatar
Guys, PM me your email address and I'll send it....
Old 06-22-2013, 09:38 PM   #33
da-burb
"Ochre Ogre"
da-burb's Avatar
You can email me as well. daburb(at)gmail.com
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-23-2013, 11:41 AM   #34
BigRed76
BigRed76's Avatar
PM sent
Zach
Old 05-18-2014, 12:22 PM   #35
elf w/capital T
yall friggen rock DA-BURB, thanks for the photos with measurements!!
elf w/capital T is offline   Reply With Quote
Old 01-26-2016, 10:27 PM   #36
lawest
Mark the cut out using the template with the Old Aire kit, drill around the perimeter with a 1/2" drill bit.
Use nibbling tool to remove remaining metal right up to the mark and finish smoothing with a file.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 01-26-2016, 10:38 PM   #37
72c105speed
What holds the top screw on the vent?
72c105speed is offline   Reply With Quote
Old 01-26-2016, 10:49 PM   #38
da-burb
"Ochre Ogre"
da-burb's Avatar
it is a sheetmetal J-clip very similar to the ones under your dash cluster.
Old 01-26-2016, 11:05 PM   #39
718jwh
I bought a A/C dash from someone here on the forum just the two ends, then I put clear tape over the holes and around dash to ends and cluster cutout and layered fiberglass over the holes, after it cured I marked the center of the hole, put the fiberglass template on my non A/C dash marked the center hole and area hole saw would not cut got a hole saw think 3-1/2" cut the hole then just used my Dremel to cut the small amount left to look like the factory, went pretty fast.
718jwh is offline   Reply With Quote
Old 01-27-2016, 11:53 AM   #40
snipescastle2
snipescastle2's Avatar
Talking Re: cutting holes for factory AC vents
I have the two outer pieces of sheet metal that have the holes for the ducts I cut out of an a/c dash, if anyone wants them, I wont be needing them anymore. free, just pay the postage....
Let me know.
Ben
snipescastle2 is offline   Reply With Quote
Old 01-27-2016, 01:04 PM   #41
69Tom
69Tom's Avatar
Let me know.
Ben
Ben, I'm interested. Sending PM....
69Tom is offline   Reply With Quote
Old 06-11-2017, 11:22 PM   #42
Cyborg
Does anyone have a template they could send me? Looking to use factory vents with the vintage air kit I am installing.
Cyborg is offline   Reply With Quote
Old 06-12-2017, 12:56 PM   #43
tinkerdad
I should, I'll check when I get home.
tinkerdad is offline   Reply With Quote
Old 06-12-2017, 01:16 PM   #44
Cyborg
That would be great! Hoping to wrap up my install by the end of the week and know I would regret cutting holes for the vintage air vents.
Old 06-14-2017, 07:07 AM   #45
tinkerdad
I have some that I cut out of an A/C truck, not so sure when I can get them in the mail
Old 06-16-2017, 07:40 AM   #46
Cyborg
Pm'd you, I can hang the vent hoses under the dash until you have time.
Old 02-01-2020, 10:16 PM   #47
Willie Makeit
Willie Makeit's Avatar
Anyone have a copy of the template that was floating around in this thread? Thanks!
Willie Makeit is offline   Reply With Quote
Old 02-01-2020, 10:39 PM   #48
Jason Banks
Jason Banks's Avatar
I recently did this and used a template like in post 38 above. It wasn't that one exactly but very similar, where it had the shape and some reference dimensions, so I could adjust the size it printed.
I cut out the opening and taped it to the dash. Then I traced the opening with a pencil on the dash.
I used a cutting wheel and cut out a chunk of metal and then used a nibbler to cut out much of the rest and then fine tuned the shape of the hole with an air file(the belt sander kind). The air file was amazing to get the final shape. It would be hard to tell the holes were not factory cut.
Jason Banks is offline   Reply With Quote
Old 02-02-2020, 03:53 AM   #49
randy500
I have dash cutouts left right and center, free to borrow.
I also have cab light cutouts for the light and switch.
$75 deposit, you pay shipping both ways, fits in small flat rate box.
Send me a private message for my phone number, then text me your name and forum name, keep me updated, i don't want to loose them.
randy500 is offline   Reply With Quote
Old 04-04-2024, 06:15 PM   #50
tmino1983
New Member
Does anyone still have the template they could send me for the stock openings? Just ordered the vintage air kit but going with stock vents.
tmino1983 is offline   Reply With Quote
