How to find new alternator?
So my 68 gmc originally had a 327. The previous owner swapped in a 350. I need to buy a new alternator. How do I make sure I get the correct alternator at the parts store without bringing my alternator and putting it on the counter since this is my only vehicle.
Junior Member
Re: How to find new alternator?
I usually go to O'Rielly's website and check the parts for both engines. When you look up a part they have a compatibility tab that can be selected and it will tell what engines a part will fit.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Active Member
![]() Join Date: Jul 2007
A pic of your alternator and engine setup would help (front and back). Here's a good article on id'ing them.
http://www.madelectrical.com/electri...elcoremy.shtml
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
if only vehicle ?? how about driving it to autoparts store??
then if there is a question have them walk on out an have a look
I agree...charge the battery fully and drive there...its 2 bolts,change it in the parking lot .at least then when you get the defective one you can try another...or put in a regulator when it still doesn't charge....most parts houses cant look up the right one even when you're holding it
![]() Join Date: Dec 2006
Get the regulator too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Unless you just have to have stock, take this opportunity to swap to a later integrated regulator version alternator and ditch the old mechanical regulator. There is tons of info on this swap. You could also swap to an even later CS144 (stay away from CS130). There is much info on that swap too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
