06-24-2013, 10:04 AM | #1 |
Carburetor Recommendations
So I've finished up the rebuild of my 305 finally, but now It's time to trash this quadrajet and get a new carb. The quad ran nice and I have it all tuned, but the fuel filter housing is leaking and the throttle shafts are worn so I need to move on. I'm just looking to see what brand and size you guys recommend. I just havn't tried enough carbs to know whats the best run for your money.
I care more about economy than power, but am not trying to build a dog of a motor either. I would think 4 bbl Vacuum Secondaries under 700cfm is probably my best option, but I am leaning toward the Edelbrock performer 600cfm and I don't think its a VS. Want to stay with electric choke. I know many will say buy another quadrajet, but honestly I'm trying to buy a used carb and I can only trust a re-manufactured quadrajet. Also, I'm tired of constantly going back and tuning, and I have heard that Holley's are like that sometimes. I'm not sure how they compare to quadrajets though. Vehicle Specs: 1983 305ci bored .030 Dished Pistons Mostly Stock 416 Iron Heads 9.5:1 Static Compression RV Camshaft 2101 Performer Intake Long tube open Headers TH350 2.73 10-bolt Stock 15" Wheels Let me know if you need any other info.
1983 Chevy C10 LWB 305 SBC bored .030 with cast dished pistons Summit RV Camshaft 204/214 .424/.444 416 Iron Heads Performer Intake, Quadrajet, and Flowtech Long Tubes TH350 2.73 10 Bolt Last edited by Organism_ike; 06-24-2013 at 10:11 AM. |
06-24-2013, 10:50 AM | #2 |
Re: Carburetor Recommendations
I replaced the Q-jet on my 350 with the Edelbrock's Performer 1406, never looked back. It a whole lot easier to adjust.
06-24-2013, 11:17 AM | #3 |
Junior Member
It seems this a subject where you will get many opinions. I guess it depends on what people have had good luck with.
I am running a Holley 1850 on my 454, it is a manual choke though. Many say it is too small for my engine, but the engine seems to like it. My truck has a 454 backed by a SM-465 and 3.73 rear gears. My son likes the Edelborcks and has good luck with them.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-24-2013, 11:22 AM | #4 | |
1983 Chevy C10 LWB 305 SBC bored .030 with cast dished pistons Summit RV Camshaft 204/214 .424/.444 416 Iron Heads Performer Intake, Quadrajet, and Flowtech Long Tubes TH350 2.73 10 Bolt |
06-24-2013, 11:54 AM | #5 |
I've been pleased w/ edelbrock 600 cfm 1405 on sb. I'd buy it again. Gets good hwy mpg and good seat of the pants performance.
I happen to prefer manual choke. I find edelbrock tuning and maintenance easier than autolite, quadrajet and stromberg. Don't know how carbs compare regarding heat soak. |
06-24-2013, 07:24 PM | #6 |
I've always been partial to the Qjets. However its the early ones. Not the electronic ones. A Qjet takes a little time to set up, but when done, they work well. I know we have scared our share with the derby cars I have tuned.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
06-24-2013, 09:16 PM | #7 |
I would do a properly rebuilt Q-jet first, but if you must have a highrise intake a Edelbrock.
Skip the holley till your making big power. They can run great, but they require more time. |
06-24-2013, 09:31 PM | #8 |
Is your intake a square bore? If so, a Edelbrock 1406 (electric choke) will work perfectly
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
06-24-2013, 09:52 PM | #9 |
I'm partial to Edelbrocks for my street-driven, workhorse stuff. It is true they leave some power on the table, but they are very simple and reliable.
Now, if I was racing or had a serious weekend-warrior/stoplight-brawler...well, I'd bite the bullet and get someone to show me around a good Holley.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
06-25-2013, 12:24 AM | #10 | |
Edit: The part number he listed shows the intake as being drilled for both square flange and spread bore.
06-25-2013, 01:03 AM | #11 |
put a good quadrajet on it, thats going to get your best mileage
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-15-2013, 01:01 PM | #12 |
I'm also running a quadrajet on a sb 350. Would an Edelbrock 1406 bolt right up to the existing manifold on my engine or would I need to swap that out also? I believe the qjet is an electric choke.
07-15-2013, 01:50 PM | #13 |
If your current manifold has square bore then is does. With spreadbore you can use an adapterplate (20-30$)
07-15-2013, 01:52 PM | #14 |
07-15-2013, 01:55 PM | #15 |
Cruzzzn' Vet
Can't beat a well tuned Qjet.
07-16-2013, 07:44 PM | #16 |
I like the idea of a spreadbore carb, I've heard great things about the Q-jets. However, my personal experience with Q-jets has been nothing but bad, can't tune, can't find anybody locally that knows how to tune them either. And I'm not new to carbs, I can rebuild an Edelbrock with my eyes closed. Still can't get that dang q-jet to tune properly.
My 1406 might not be the most powerful or most fuel-efficient, but it's never given me even an ounce of trouble. It doesn't even have the choke hooked up properly and it still never fails to start.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
07-16-2013, 08:53 PM | #17 |
I'm in the same boat as ike. I've thought about putting the 1406 on my truck with the edelbrock alum. intake. Has anyone done that on stock and had a noticable gain? I'm sure with headers and duals it'll open the truck up even tho I like how quiet it is right now. Also what mods would be required to make the edelbrock fit? Just to know before getting in there.
07-16-2013, 09:41 PM | #18 |
I would go with a 600 Holley vs personally. I had a 1406 on my truck with the 305, best mileage I could muster was around 11-12 hwy. I had to replace the accelerator pump multiple times, was a pita to get started in the winter and all around ran like crap. I bought a new Holley put it on and made a few small tweaks, and oh man what a complete different truck!! Mileage immediately went to 15-16 hwy, cold starts were cake, truck was a ton smoother etc. everything was all around better. Not to mention tuning a Holley is a ton easier if you need jet changes etc. in the 4 years it was on my truck before the ls swap, I never once had to touch it except when I added the ac kickup solenoid. A couple quick tweaks and back on the road like a champ.
Posted via Mobile Device |
07-17-2013, 01:41 AM | #19 |
Q jet holley and edelbrock when you tune the fuel curve the same will fuel the same. Qaudrajunk in the trash is a good idea. A Holley 600 is easy to tune and reliable. Fuel mileage will be about the same. A 500cfm holley will prob be ideal
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-17-2013, 03:47 AM | #20 |
My vote... spend the money on a wideband to monitor your afr's. You have the Q-jet already, so hit up the yards and pick over the Q-jets for different rods, jets, springs. I'm not going to say put them in your pocket, but I'm pretty sure you could acquire them for next to nothing. Get a good rebuild kit from your local supplier or even eBay. You can lean the primary's out to the 16's to run it lean under cruise and increase mileage. A nice HEI with Vac advance hooked up and nice advance curve will help as well... Getting back on track, your secondary's you can swap jets and rods to richen it up when WFO, shoot for 12.5:1. These just take time like anything else... if you cant get the Q-jet to run right, go for a 1406 or the 500cfm model. Since you will already have a wideband you can tune the Edlebrock in the same manner. Ed's are super easy to tune with a wideband and you can see exactly what you're doing when you make changes. I know its going to sound archaic, but get a book on it... a lot more in there than boring print and a google search will provide.
07-17-2013, 08:10 AM | #21 |
One of the biggest mistakes people make to is to over carb your engine. Unless you are going to be turning 7000+ the most you would ever want is a 600. I have used all three types mentioned here. Hard to beat a well tuned Q; and After that I have run Holleys. From a 390 on a straight six to a 600 on a small block. Vacuum secondaries are a must.
1977 K10 6ft Stepside L6 1978 C10 8ft Stepside 400 1980 C10 8ft Widebox with Uncle L6 1986 K35 Not a dually 350; 79 K20 Stripped 1973 and 1976 Chevy Truck Trailers 1995 Impala SS LT1 |
