06-24-2013, 08:29 PM | #1 |
Big Block Lowering Question
Im installing a BBC into my 73 1/2 ton. I will have 2.5 drop spindles. Im going to use 3/4 ton BBC coils. How much should I cut to achieve a total of 4" drop on the 1/2 ton?
06-24-2013, 08:41 PM | #2 |
Re: Big Block Lowering Question
I have one that is bb 2.5 drop spindles I cut one round off for a another 2in drop it was a 3/4 change to 5 lug
06-25-2013, 12:26 PM | #3 |
You pullin apart the 'burb already?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
06-25-2013, 12:29 PM | #4 |
06-25-2013, 01:59 PM | #5 |
I have a 78' big ten. five lug. came stock with the 454.
I've installed a 3" spindle and cut 2 full coils from the spring. It has about a 6 inch drop. So If you wanted a 4" drop on yours, you should probably only cut off 1 coil which is about 1.5-2 inches. Measure twice, cut once (or multiple times if you want to go lower ) |
06-25-2013, 07:37 PM | #6 |
Looks good. But a 3/4 ton bbc spring is still different than a 1/2 ton bbc spring. Im figuring I might need to cut 2 coils.
06-25-2013, 11:05 PM | #7 |
two coils will be to much the ride will be bad every full coil cut off is 2" of drop
