#101 |
VA72C10
![]() Join Date: Mar 2008
Re: 1970 project/ DD "instant death"
Looking good.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#102 | |
Plus I don't mind the fabrication Next step will probably be a body drop to get the rockers on the ground which should get this pig level When it's aired out its kinda a bummer seeing it so close to the ground, but seems so far lol Posted via Mobile Device
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#103 |
#104 |
Got some goodies
![]() ![]() Just gathering some fittings and valves to clean up my setup before I start doing the bigger projects Posted via Mobile Device
#105 |
Nice build! Just finished the body drop on mine shouldn't be much trouble for a fabricator like urself! I'm subscrided
Posted via Mobile Device |
#106 | |
Which way did you do yours? Conventional or chop the frame Got any pics of yours Posted via Mobile Device
#107 |
My only update for this hot weekend
![]() Posted via Mobile Device
#108 |
Lovin' the build. Not a fan of the copper tubing. I highly recommend using steel tubing or DOT plastic air lines.
Keep the updates coming. |
#109 | |
And it's something different Dot fittings are mainly rated for big rigs otherwise its just a name basically The copper is plenty strong for this application The only dot hardware I have are the 1/4" lines ran from front to rear and thats to the gauges in the cab. There's not enough going on to need brass fittings I get most of my air line fittings a grainger and pay like $2-3 a piece Never had a leak and they work great, even the cheap plastic check valve from the has worked for 2 years My main reason for the copper tho is that you don't really see it to often. The metal is just soft enough for push to connect fittings to work also Posted via Mobile Device
#110 |
Haven't got my pics up yet this might help... Make sure u angle the front of the frame by the tranny crossmember though so u don't have huge holes like in the link! http://67-72chevytrucks.com/vboard/s...ad.php?t=70926
#111 | |
Curious if he capped the end of those cuts or made some gussets for strength Posted via Mobile Device
#112 |
I capped mine. I just used this as a reference and improved upon his mistakes. Don't learn from ur mistakes... Let them screw up first lol!
#113 | |
My biggest challenge is figuring a way out to do it with my daily driver I have been doing everything in stages and planning it all out so I don't have to park it I'm kinda thinking for the first step to lower all the body mounts first and make some risers to keep the body where it is Then cut the frame and finish that. I can modify the tranny hump too and raise it a couple inches My main concern is the driveshaft, do you thing I will have to raise the tunnel for that? Posted via Mobile Device
#114 |
Posted via Mobile Deviceheres one in the begining
#115 |
In all honesty I jumped the gun and cut my tunnel before I test fitted and didn't even need to but we are talking two different cab styles... Idk I would suggest doing the vs then test before cutting may just make extra work. Plus I'm running a 305 v6 with four speed granny! With ur skills u should be able to do it in a weekend... All added up took about 24 hours +/-
#116 |
By the way did mine a max of 4" u prolly won't need that with the bags.
#117 |
i figure go big or go home lol
id much rather have the clearance instead of tearing off a crossmember going 65 on the freeway lol the highways here suck!!! but i totally agree, ill fix the mistakes of other bd's haha gunna be fun!!
#118 |
cool build
#119 |
#120 |
how did you make your side markers very coooool
#121 |
Thanks for noticing!
Your the first person to ever to comment those My old side markers were all broken and cracked up, at least the lenses. I finish peeling off the old red and clear lenses off and kept the bracket or backing of them I painted the backing black and cut out the pattern of the back plate on metal I had laying around I forget what it's called but it has a lot of holes in it lol Once the were cut out I left them bare metal They were supposed to rust lol Posted via Mobile Device
#122 | ||
Don't end up in prison singing love songs to a guy named "Buba" Use DOT approved hose and fittings in your Air System. Posted via Mobile Device Posted via Mobile Device
#123 |
Not to contradict you but from my ten years in the heating and air field we use the exact same diameter copper and thickness for our units in which some vibrate like hell. And with the new r410a Puron it runs 450+ psi on that exact same tubing... So I'm not sayin but I'm jus sayin! Lol
#124 |
Doubtful
#125 |
ill take my chances, i had them on my s10 with no problems.
dot approved like i said is just a name. its like buying name brand appliances or clothing. looks the same and does the same. my buddy owns the local fitting shop and knows his stuff so i go to him if i have any questions. if there is a situation that you need you system inspected at a truck stop or weigh station they can check the labled fitting "dot" if there is not dot you can be given a huge fine but the ones not labeled dot are still made in the same factory on the same manufacture line as for the copper is has alot of strucktural integrity. there is no drastic bends in my air system to give this tubing the stress in rough or vibrating conditions, yes it my discolor when exposed to the elements but is still plenty strong
