06-26-2013, 05:39 PM | #1 |
high hump transfer case
is there a factory template to find to cut the factory hole in a high hump with a np205 automatic. the high hump has dimples stamped in hump but the pictures I see on here are oval shape and not sure where to cut the hole. need some direction if someone could help please
06-26-2013, 06:02 PM | #2 |
Re: high hump transfer case
There might be something in the assembly manual but don't expect a pattern with exact measurements. Here is a thread with some pictures of mine but I will look for more with the hump removed.
http://67-72chevytrucks.com/vboard/s...d.php?t=577384
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 06-26-2013 at 06:21 PM. Reason: add images |
