Old 06-26-2013, 08:31 PM   #1
crazy longhorn
Fabricate till you "puke"
I need your help ,once more guys?
5.3, I have all the tork specks& sequence on the rear cover/head bolts. I could not find the sequence on the Pan? I assume, start in center, and cross to the outer ends? ....the long bolts be last(back end)? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-26-2013, 08:58 PM   #2
clinebarger
Re: I need your help ,once more guys?
That's what I do.
clinebarger is offline   Reply With Quote
Old 06-26-2013, 09:54 PM   #3
crazy longhorn
Thanks Cline, your thoughts on the old pan to line things up, worked slicker than snot! That GMPP cover on the rear, dropped the big F on, no issues. Longhorn
