Old 06-27-2013, 06:54 PM   #1
Damon23
Damon23's Avatar
255/50/17
I'm getting ready to pull the trigger on tires and am going to be putting the size tire in the title on a set of 17x8 soft 8's with 4in backspace. The truck has been lowered 2.5in in the front via spindles and has 2in drop in the rear with shackles. I know I will need spacers in the rear so they are not so tucked in. In your experience will I have a problem in the front?
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 06-27-2013, 07:29 PM   #2
bdiamond
Re: 255/50/17
Not sure on your fitment issues, sorry. That size tire isn't made by too many manufacturers. I ran the Rikens and wasn't very happy with them. They were cheap but they would flat spot overnight it seemed. They would ride rough for 5-10 miles then they were ok. I am now running Kumhos and am happy with them.
bdiamond is offline   Reply With Quote
Old 06-27-2013, 07:34 PM   #3
Damon23
Damon23's Avatar
Re: 255/50/17
I had Rikens on a 80 Camaro I sold to buy this truck. I know what you mean about the flat spotting.
Old 06-27-2013, 08:49 PM   #4
Sodell
Sodell's Avatar
Re: 255/50/17
I don't think you will have any problems. I ran a set of 255/70/15 on a 4 inch drop and they rubbed a few times on the upper fender well taking large bumps, but wasn't bad.
The 255/70/15 are 29"x10". The 255/50/17 are 27"x10. I currently am running 235/70/15 (front) which are 28"x9.3" and have had no problems with the rubbing.
Hope this helps. You could probably run a little bigger tire for a better ride.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-27-2013, 08:53 PM   #5
Sodell
Sodell's Avatar
Re: 255/50/17
I also think the back spacing on the Rally's rims I am using is 4", you may want to put them on with out the spacers first.
Scott
Old 06-27-2013, 09:33 PM   #6
Damon23
Damon23's Avatar
Re: 255/50/17
Thanks for your input. Maybe I will go to a 55 series.
Old 06-29-2013, 06:15 PM   #7
Damon23
Damon23's Avatar
Re: 255/50/17
The soft 8's actually have a 4.5 backspace. So, I think I'm going to run a 1 inch spacer and ago with a little bigger tire. The fronts I think I will be alright. Thinking of a 245/55/17 up front and a 265/60/17 out back.
Old 06-29-2013, 09:52 PM   #8
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: 255/50/17
I think Boatpuller is running a similar size to that with his 17s
killthewabbit is offline   Reply With Quote
Old 06-29-2013, 09:59 PM   #9
Sodell
Sodell's Avatar
Re: 255/50/17
I am planning 17's or 18's after I get the body work finished. I want a little meat on the rim for ride quality. Curious to how they look, please post pics when you get em on.
Scott
