Old 06-29-2013, 05:39 AM   #1
bikernut
bikernut's Avatar
key and seat belt buzzer
I know this may sound foolish but in my 03 GMC 3500 4x4 the buzzer doesn't sound when the key is left in the ignition and the buzzer doesn't chime when the seat belt isn't hooked, but the light flashes in the dash. I can't seem to find a fuse for this or the buzzer, can some one tell me where the buzzer is and what fuse controls the buzzer in case I want it to work. thanks
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 06-29-2013, 06:53 PM   #2
MadManAndrew
Re: key and seat belt buzzer
Mine doesn't chime when my seat belt is off either. Try turning the headlights on with your truck off/key out. If it doesn't chime then there is definitely something wrong.
Does it really bother you that much? Lol
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 06-29-2013, 10:02 PM   #3
clinebarger
I think 03 & up Chime through the radio speakers, Aftermarket radio??
clinebarger is offline   Reply With Quote
Old 06-30-2013, 05:30 AM   #4
bikernut
bikernut's Avatar
doesn't work, tried that and I would like the key to chime when I forget to remove the key from ignition.
Factory AM/FM radio
Old 06-30-2013, 11:42 AM   #5
MadManAndrew
If your left front or right front speaker is not working, you will not hear the chime.
Also, check the black connector under the driver's seat. Is the blue wire connected?
Old 06-30-2013, 09:02 PM   #6
bikernut
bikernut's Avatar
checked and both speaker are working.
to cut to the chase where is the chime located or where is the devise that activates the chime located?
Old 07-01-2013, 02:12 PM   #7
truckdude239
truckdude239's Avatar
Do your dome lights work when door is opened?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-01-2013, 07:25 PM   #8
bikernut
bikernut's Avatar
every thing works in the truck except the key/seat belt chime, that is why I am on the hunt to find it in the truck.
Old 07-01-2013, 08:35 PM   #9
truckdude239
i do bleive it plays though teh radio on 03 and up not 100 percent sure on that
David fuller
2000 Tahoe 5.3l 378
Old 07-02-2013, 05:35 AM   #10
bikernut
bikernut's Avatar
where does it get the chime from, as there must be some item that activates it so it can chime
Old 07-02-2013, 04:00 PM   #11
MadManAndrew
Data message from the BCM. If that was the problem your radio would not even turn on. Try pressing and holding the "6" preset on your radio with it and the rest of the truck off, then checking for the chime again. If that doesn't do something, something is wrong with your radio or the left front speaker. Those are the only culprits.
Old 07-02-2013, 08:12 PM   #12
bikernut
bikernut's Avatar
I'll try that but that still doesn't answer my question what activates the chime and where is it located?
Old 07-02-2013, 10:20 PM   #13
MadManAndrew
I did answer.
Old 07-03-2013, 04:30 AM   #14
bikernut
bikernut's Avatar
but what is the BCM?
thanks
