Old 07-01-2013, 10:19 AM   #1
papastrk
How much rear axle to frame clearance???
I have been working on my rear suspension on my '59 task force truck and need help on how much clearance you normally should have on the TCI (or flipped) leaf spring setup between axle tube and bottom of frame at ride height. I don't intend to run it extremely low, but was thinking I may c-notch the frame now if it needs it. Can some of you measure your trucks axle clearance for me? Thanks.
papastrk is offline   Reply With Quote
Old 07-01-2013, 11:59 PM   #2
papastrk
Re: How much rear axle to frame clearance???
Can some of you help me with a measurement/ Thanks
Old 07-02-2013, 12:28 AM   #3
sqrlnts
Before I installed my step notch I had around 2" with an empty gas tank. My advice is to install the notch now instead of wishing you would have later.
sqrlnts is offline   Reply With Quote
Old 07-02-2013, 01:22 AM   #4
parkwood
parkwood's Avatar
Here are a couple pictures of a TCI spring kit... you can see how low it sits and this is before the bed was put on... As far as I know after the owner got it back and drove it he never had a problem of it hitting... but it would not hurt to install a c-notch just for peace of mind if for nothing else... like was said before better now than to wish you had...
parkwood is offline   Reply With Quote
Old 07-02-2013, 07:48 AM   #5
hammerdog57
hammerdog57's Avatar
Heres a pic of my tci spring kit. Four inches from frame to axle tube. 3.5 inches from axle u bolt to frame. This is with no bed weight and empty gas tank.
hammerdog57 is offline   Reply With Quote
Old 07-02-2013, 09:10 AM   #6
mknittle
mknittle's Avatar
My moms 90s Dakota sits at 4" empty it is in like new condition. So that is what I shot for. I figure the Dakota rides nice and doesn't bottom out I can adjust my52 to match that window.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-02-2013, 09:57 AM   #7
papastrk
Thanks everyone. That is exactly what I needed to know.
Old 07-11-2013, 01:38 PM   #8
focusedontheprize
focusedontheprize's Avatar
After seeing this, I ordered a set of the TCI leaf springs. Thanks for all the info.
focusedontheprize is offline   Reply With Quote
