Old 07-02-2013, 07:47 PM   #26
tlcrz1972
tlcrz1972's Avatar
Re: quick ratio steering box ( which to buy )
My dealing with a so called quicker steering box is that 72 and earlier were 4.5 turns lock to lock. And I know from mid 70 up they were all 3.5 turns lock to lock. It is a definite improvement from original. Plus it isn't so sensitive that I still can be a carefree going down the road and yet it still responds very nicely.
As far a new or reman, It depends on your comfort level with you parts supplier.
tlcrz1972 is offline   Reply With Quote
Old 07-02-2013, 08:34 PM   #27
Tillik
Tillik's Avatar
I just replaced my leaky box with an Orielly's Cardone one. So far so good. My steering improved greatly. Hope it doesn't wear out too soon. It was a pain in the ass. I had to grind one of the casting bosses down so it would fit in my 67. Going to install my 19 dollar stock sway bar(Junkyard) this week and see how it changes my handling.
My boss suggested I buy an extreme ratio one from Summit. It's not a show or race truck so I went with the less expensive option atm.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 07-04-2013, 10:58 AM   #28
hoovers71
Thanks. I tried to get one at cpp that has a lifetiime warranty with it, they do not have them for 4x4.
What is the warranty on yours?
I am replacing a Napa rebuilt that is less than 2 yrs old! So I am looking for something that should be reliable.
hoovers71 is offline   Reply With Quote
Old 07-04-2013, 12:18 PM   #29
Lee H
Lee H's Avatar
Red Head Steering Gears. Not cheap but will probably be the last box you have to buy. I think Wes carries them and they are a better ratio than stock.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-01-2019, 04:03 PM   #30
Mbradley026
Is the steering gear from an 87 considered a quick steer ratio.
Mbradley026 is offline   Reply With Quote
Old 04-09-2019, 01:55 AM   #31
Porterc10
Sorry to resurrect an old thread here. I was reading this thread a while ago and decided my 67 needed to have power steering so why not give a 77 c10 box a try. My question is wether anyone knows what I need to do for an intermediate shaft and rag on that. I’m putting in a new tilt column also. Thanks!
Porterc10 is offline   Reply With Quote
Old 04-09-2019, 03:49 PM   #32
67/Heaven
67/Heaven's Avatar
My set up using a cpp box, your 67 will not need to be dimpled with this box.
http://67-72chevytrucks.com/vboard/s...d.php?t=729738
67/Heaven is offline   Reply With Quote
Old 04-09-2019, 04:06 PM   #33
Porterc10
I already bought the steering box. If I have to dimple it’s not ideal but I can do it. I’m just not sure on the intermediate shaft and tag joints.
Old 04-09-2019, 04:10 PM   #34
67/Heaven
67/Heaven's Avatar
The part numbers that i used are in the post that i sent you, hope it helps I bought them through summit
RJC-730R is the Ragjoint
CP UHK universal hose kit both from CPP or summit racing
Old 04-09-2019, 04:13 PM   #35
Porterc10
Right on! Thanks! Hopefully those work with the later model steering box.
Old 04-09-2019, 04:18 PM   #36
67/Heaven
67/Heaven's Avatar
Any incidental parts you may need I got from JJ inline parts. ( I believe he is in Oregon also )
http://www.jjinlines.com/
You can email him but if you PM me i can give you James' cel number
Old 04-09-2019, 06:33 PM   #37
C10_crazy
C10_crazy's Avatar
I used an AGR steering box on my C10. They're a little pricey but I've been happy with the performance.
C10_crazy is offline   Reply With Quote
Old 04-09-2019, 08:47 PM   #38
webfoot
I'll just reiterate this right here. Just put one in mine and its MUCH better than stock.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 04-19-2019, 03:36 PM   #39
engineer_gregh
engineer_gregh's Avatar
I installed a rebuilt Cardone part number 27-7512 that I ordered from Amazon. It's for a 1977 half ton C-10. Works great with no play and no more leaks.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 09-07-2020, 03:46 PM   #40
425buick
While looking for this same info for myself I noticed a few people referring to the GM800 box used on passenger cars. Way different than truck boxes. They mount on the inside of a wide frame, trucks on the outside of a narrow frame. They are great boxes but basically built 180 degrees in architecture. Won't wok.
425buick is offline   Reply With Quote
