Old 07-03-2013, 08:48 AM   #1
Mrdsmoke420
Smoke from one side of exhaust
I have true dual exhaust on this 1987 chevrolet truck. The drivers side tailpipe smokes. Any ideas on how i would stop it? If you give me an answer like 'check this' could you also explain on how to 'check' what. You are talking about. Thanks! Any info is greatly appreciated!
Mrdsmoke420 is offline   Reply With Quote
Old 07-03-2013, 09:19 AM   #2
JMac11
JMac11's Avatar
Re: Smoke from one side of exhaust
Could Be:
Bad valve stem seals on that bank
Broke ring on that bank
Clogged oil return on that bank
I would not worry until it fouls a plug or consumes more than one quart every 3000 miles.
JMac11 is offline   Reply With Quote
Old 07-03-2013, 10:18 AM   #3
SCOTI
SCOTI's Avatar
What color is the smoke? White or black?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2013, 10:26 AM   #4
Mrdsmoke420
The smoke is white. It is not the thickest smoke, but after a little drive around the block it gets thicker
Old 07-03-2013, 11:05 AM   #5
SCOTI
SCOTI's Avatar
'White' smoke from one exhaust bank typically means moisture in the combustion chamber which means failed head gasket or leaking intake gasket @ one of the cooling ports.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-03-2013, 11:28 AM   #6
JMac11
JMac11's Avatar
Turbo 350??? Could be sucking trans fluid through modultor valve also....
Old 07-03-2013, 11:35 AM   #7
SCOTI
SCOTI's Avatar
Ahh... Very true as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-03-2013, 12:36 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
blown head gasket or cracked head my guess, especially being on drivers side....pull #1 cyl spark plug and take a look at it
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-03-2013, 01:27 PM   #9
Rufton
I'd start by labeling plug wire addresses.
Then pull plugs 1,3,5 and 7; label each plug address w/ sharpie.
A a pic of the plug's business ends would be nice.
Variance of color and deposits may produce suspects.
Rufton is offline   Reply With Quote
Old 07-03-2013, 03:28 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
Compression test. That will help narrow it down if the plugs aren't obvious.
Old 07-03-2013, 04:01 PM   #11
TheBlueBomber
TheBlueBomber's Avatar
The duwhatahicky?? I'm having the same problem and the transfluid is black. I dont mean to hijack OP.
TheBlueBomber is offline   Reply With Quote
Old 07-03-2013, 04:21 PM   #12
SCOTI
SCOTI's Avatar
The modulator on the side of the trans can go bad & allows trans fluid to get pulled up into the motor under certain loads causing one heck of a smoke show. Usually when it occurs, the trans doesn't shift 'right' either.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2013, 01:45 AM   #13
TheBlueBomber
Like slams into gear when you put it in drive, or shifts hard where it puts you back in your seat "right"?
Old 07-04-2013, 10:05 AM   #14
SCOTI
SCOTI's Avatar
Yes. It also may not want to shift @ all (requiring you to shift through each gear manually) similar to when the vacuum line is removed from the modulator.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2013, 09:09 PM   #15
TheBlueBomber
Interesting...
Old 07-05-2013, 12:23 PM   #16
Axle
Axle's Avatar
Re potential bad head gasket, if you look in your radiator, do you see any whisps of black/brown/rusty fluid? If you do (and have had solid green in the past) you probably have a head gasket that is starting to fail. Took two years before mine finally let go, but I finally had an answer to where that rusty colored stuff was coming from.
Alex.
Axle is offline   Reply With Quote
Old 07-13-2013, 04:53 AM   #17
Mrdsmoke420
pulled spark plug 1. ran a compression test. 0. nothing. the gauge wont even move. but what is weird is i ran a vacuum tester on the spark plug 1 and it showed compression through that, but after getting ahold of a compression tester it shows nothing. what does that mean? 3 and 5 are at 100.5 or so.. what does this mean? havent got too the others yet. taking a break. will check all and update the thread. thanks for the help!
Old 07-13-2013, 08:36 AM   #18
Rufton
You could apply compressed air to #1 and see if air escapes through ex pipe (stuck ex valve), dip stick tube (possible ring/piston failure), etc for clue.
Old 07-13-2013, 04:39 PM   #19
Mrdsmoke420
Ok i will try that. Any others that had this happen?
Old 07-13-2013, 04:41 PM   #20
Mrdsmoke420
The driver side is
1- 0
3- 100.5
5-100.5
7- 115
Passenger..
2-0
4-125
6-130
8-145
Old 07-16-2013, 07:41 PM   #21
Mrdsmoke420
nobody has an answer to this?
Old 07-16-2013, 08:20 PM   #22
Rufton
Did you pull vc to see if valves stuck open?
Old 07-16-2013, 08:32 PM   #23
Mrdsmoke420
What do you mean by vc. I have not tried to see if a valve was stuck, no. How would i do this
Old 07-17-2013, 08:12 AM   #24
SCOTI
SCOTI's Avatar
vc = valve cover.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-17-2013, 11:28 AM   #25
Rufton
Compare #1 and #2 valve travel vs other valves. Check valve adjustment.
I've seen severely worn rings/cylinder produce 60 psi compression.
Haven't had the pleasure to see compression for broken rings/pistons.
With 0 psi compression the culprit should be easy to find.
