350 to 700r4
I just ordered a 700r4 and all the necessary stuff needed to swap over from Bowtie Overdrives. Anyone else use them? Any got ya's
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 350 to 700r4
I have a BTO 700r4 in my K20....not running yet but close. See the link in my signature below...good luck!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Dec 2012
Re: 350 to 700r4
Did you get the driveshaft also?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: 350 to 700r4
I'm going to have a new one made once we get it installed.
What about the speedo?
Re: 350 to 700r4
I had a gear on mine installed when it was built. I do have to change it now though. I am about 10% off.....When I do calcs for mileage or distance, I have to do math.
Also I did a Big Transdapt cooler for it. The biggest PITB for me was the crossmember. It just took time. Best of luck on the swap. You'll really love the transmission when you get it dialed in.
#6 | |
Re: 350 to 700r4
Need to look into an additional cooler!
Re: 350 to 700r4
I don't have a bowtie trans, just a rebuilt craigslist buy... but I do have bowtie's TV cable setup. Six years and 80,000 miles later it's still working great.
![]() Join Date: Nov 2004
Re: 350 to 700r4
I purchased a pressure gauge to fine tune the trans TV cable cam adjustment on the TVmadeEZ kit. I can't remember what they are off hand, but a google search should find them.
I have a 350 with a 700R, TVmadeEZ and lock-up/brake switch. Been on the truck since '06.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: 350 to 700r4
What about the lock up switch? (Think I'm about to ask a lame question) How does that work? Do I need to flip a switch every time the truck goes into 4th?
Re: 350 to 700r4
you will be very happy with the switch
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 350 to 700r4
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: 350 to 700r4
I got my 700r4 from them 11 years ago....still works as it should.
They are very good about helping you get the right speedo gear, I had to try several before getting it close enough. Posted via Mobile Device |
#13 | |
Re: 350 to 700r4
It locks itself when gear selector is in 4th, the switch is for if you need to drive in 1,2,or 3 for any amount of time (like when I pull my 4000# boat I run it in 3rd). Posted via Mobile Device |
#14 | |
Re: 350 to 700r4
#15 |
Re: 350 to 700r4
I have had my BTO trans for over 10 year with no problems. The lock up on converter is wired into my brake light switch with the use of a relay. So when I am in overdrive the converter is locked up and when I hit the brakes the converter unlocks. I typically shift into overdrive when I drive over speeds of 50 mph. I tow in 3rd gear only.
#16 | |
Re: 350 to 700r4
You can, thats what I do, but I have to lock the converter with the switch when I do it or the trans gets hot FAST. Posted via Mobile Device
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#17 |
Re: 350 to 700r4
Do you have the BTO lock up kit on yours?
#18 |
Re: 350 to 700r4
floatmonkey has the same one that I got from BTO works great there is a list of pressure checks they have you do or a mechanic do you can purchase it from BTO its a hose that you attach to the tranny that has a pressure gage on the other end do some simple checks in the shop then set the TV cable a few on the road and your done the pressure checks are just to verify what they set up for you by the way you call these in and any problems they will help you out I've had nothing but good things to say about these guys at BTO
#19 | |
Re: 350 to 700r4
