Old 07-03-2013, 06:33 PM   #1
lasher78
lasher78's Avatar
LMC 21 gal tank fuel filler size?
has anyone bought the 21 gal under bed tank from lmc? i am trying to find out what rhe size of fuel filler neck is?
live like you are dying
lasher78 is offline   Reply With Quote
Old 07-04-2013, 12:05 AM   #2
Trsmotrhed
Trsmotrhed's Avatar
Re: LMC 21 gal tank fuel filler size?
1 3/8"
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 07-04-2013, 01:05 AM   #3
lasher78
lasher78's Avatar
thanks
Old 07-05-2013, 09:52 AM   #4
cortcomp
cortcomp's Avatar
They are not fuel approved, but on my father in law's 57 pickup we put a 31 gallon blazer tank under the bed, and used a through the bed filler. The filler neck was like 1-3/4 and the filler through the floor was like 1 1/4. So we went to the hardware store and got a fernco coupler and all was good. Made it easy to slide the filler adapter in once the tank was up too.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-05-2013, 10:07 AM   #5
lasher78
lasher78's Avatar
what do u mean not fuel approved? what yr blazer tank did you use, and what about sending unit? was the one in that tank abke to be used or did you have to get new one for that tank?
Old 07-05-2013, 03:52 PM   #6
cortcomp
cortcomp's Avatar
it was from a 73 blazer K5 i think? we used the factory 31gal sending unit (was correct ohms for his VDO gauges), and blocked off the return, and put a vent hose + breather filter on the return line. It was a tight fit, we had to flip the spring plates and put the shocks in front of the rear end instead of behind. There were two styles, one with a straight down in filler neck and one with a 90* bend. This is in 57 chevy stepside shortbed.
By not fuel approved, i mean i don't know that fuel wouldn't eat through the rubber or mess it up in some way if the fuel line was that material. Since it's rubber and it's the filler neck and not holding gas all the time, we didn't see any issues with it, and it's a thin and workable rubber, easy to slide things into place in tight spaces where you can barely reach anything.
Old 07-05-2013, 03:58 PM   #7
lasher78
lasher78's Avatar
ok thanks ill do more inquiry on lmc tank
