07-03-2013, 08:33 PM | #1 |
seat swapping ?
Does anyone or has anyone put 60/40 or 40/20/40 split seats in a like a
1973-87 models...???? Looking to upgrade.. I heard you can put from '88-98 seats in these years..just have to modify brackets for the inner parts.. Any facts and pictures... please post back. thanks! |
07-03-2013, 08:42 PM | #2 |
Re: seat swapping ?
I just finished putting 03 silverado seats in mine. Give me a few ill go take pics of the brackets and such.
Posted via Mobile Device |
07-03-2013, 10:06 PM | #3 |
Re: seat swapping ?
I want to see how u did that, can u tell us what ya did.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
07-03-2013, 10:43 PM | #4 |
Re: seat swapping ?
I want to put 99-06 buckets/console in my 75. I would like to see that aswell!
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax |
07-04-2013, 08:50 AM | #5 |
Re: seat swapping ?
Here ya go guys. Sorry for the crappy photos, but basically I removed the sliders then took some 1/8 flat stock and bent up a few new brackets and bolted them down.
07-04-2013, 09:11 AM | #6 |
Re: seat swapping ?
I love the "98" year style of seats. I bought some front buckets for my 87 burb 6 years ago and used the stock seat brackets on them. It seemed like a couple of holes lined up and I had to drill a couple of new holes to attach them to the seat frame. they went in pretty easy. They are a little taller than the stockers but its good for me as I am short. I liked them so well that last summer I went junkyarding and picked up the mid and third seats for the burb, front buckets and a burb rear seat for my 87 blazer, front and rear crew cab seats for my 86 crew cab and a a 60/40 for the 84 std cab pickup. I am building a whole fleet of 80 chevys, all red and white with grey interiors I also found a little plastic cupholder that will sit under the arm rest on the 60/40 that works pretty good too. It seems like everybody but gm puts cupholders in their armrests.
07-04-2013, 09:18 AM | #7 |
Re: seat swapping ?
Blackpony, thanks for posting pics. that is exactly what i want to do!
07-04-2013, 01:03 PM | #8 |
Re: seat swapping ?
No prob I plan to maybe add a couple more xtra supports in the event I get into a wreck I want to ensure to seats are solid since the seat belts are part of the seat rather then the b pillars.
07-04-2013, 08:59 PM | #9 |
Re: seat swapping ?
I have a '86 4x4 4 speed, I took the old bench seat out and put in '98 60/40 split . I kept the slider assembly under the seats.I thought they where to high stock, so I cut the the mounting brackets down leaving just enough room for the slider to work. Bent up some brackets for the front of the seats to be mounted to the floor. I drilled holes for the rest of the mounts.
I left the same seat belts in the truck. |
07-08-2013, 04:39 PM | #10 |
Re: seat swapping ?
thanks guys...for the info..and the pictures...if anyone else has some ideas...throw them at me...cause im looking to put 60/40 in it..But im almost 6ft tall...and i got a big subwofer on the passenger side...if it wasnt for that ...i probably be comfortable....But i do like the folding armrest /cupholder....
07-08-2013, 07:17 PM | #11 |
Re: seat swapping ?
Did you loose any room when you installed the seat? The factory seats don't leave alot of room the way it is. Just wondering how the newer seats compare. The only thing I am not fond of is not being able to use the factory holes and having to drill through the floorboard.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
07-08-2013, 08:03 PM | #12 |
buffle
Re: seat swapping ?
We still would like info on 88-98 seats in a square. I want to use the stock frame and modify for this seat.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
07-08-2013, 08:19 PM | #13 | |
Re: seat swapping ?
Yea drilling the floor was kinda a pita. When I order new carpet and get it all fixed up, I am going to weld some bolts the the floor so I dont have to get a buddy to help me tighten up the bolts.. |
07-10-2013, 01:49 AM | #14 |
Re: seat swapping ?
Its always a good idea to use the factory mounting locations when swapping seats. You can use the factory outboard seat mounting places and use the factory inboard seat belt mount for your inside rear seat mount. Then you only need to fabricate the front inside mount. Reinforce the floor by welding metal in the area of the mount. Just bolting through the thin sheetmetal won't hold in a wreck. Even with fender washers you are taking a risk of it failing. And with the seatbelts built into the seats. You could ride the seat right through the windshield. Very messy.
07-10-2013, 10:10 PM | #15 | |
Re: seat swapping ?
07-11-2013, 01:49 AM | #16 | |
At the body shop.
Re: seat swapping ?
Posted via Mobile Device http://67-72chevytrucks.com/vboard/s...d.php?t=381564
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 07-11-2013 at 01:52 AM. Reason: link |
