Old 11-29-2003, 02:29 PM   #1
67_396
Question Has anyone Done this?
Just curious If anyone has takin a 67-72 body and put it on a '73-87 4x4 frame. What changes were made to make it fit? I ask this because I have an oppertunity to get a free frame with 350 engine, and want to know if it will work. Thanks
Jason
2003 Yamaha Blaster for sale : $1900 OBO
67_396 is offline   Reply With Quote
Old 11-29-2003, 03:29 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I believe mudder 67 has done this swap?? Could be wrong..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-29-2003, 03:54 PM   #3
Mudder
Mudder's Avatar
If you can weld and cut some its no big deal. I have pics of all the mounts and some helpful tips if ya wanna pm me your email addy.
Mudder is offline   Reply With Quote
Old 11-29-2003, 04:05 PM   #4
mikep684x4
Seeker of the big and bad
I've done three of these swaps and they look good.First,turn the rear cab mounts to the out side of thr frame and move the mount hole about 1 nch inward taward the drive lineYou my need to trim alittle off the mount because our cabs tapper down and they hit the edgeof the mount.You'll need to remove the saddle tanks but they won't fit our cabs anyway.Then from the front mount you need to go 1inch out and one inch forward of the original mount hole for the front of the cab.You will need to make a body lift for the front off the cab or raise the mount.you then need to weld a 6x6 pad,not very thick about 1/16 to the top of the leaf spring,radiator bracket on the front.Here you'll need a 4 inch lift spacer to the radiator support,don't forget to add in your bushing thickness's.The back off the cab will sit flush(about 3/4 to 1 inch above the frame.Then you will need to move your rear spring hangers forward 1 1/4 inches,BUT ONLY FOR A LONGBED!, short bed will line up.you will need to place 2 inch blocks under the bed to match the body line with the cab.The easyiest way I've found to get the bodyline right is the mount the bed and the rear of the cab then lift the front end up till the body line matches and then build the corrected mounts you need for the front of the cab and radiator support.I hope this helps and not hinders.Remember you now have somewhat of a body lift so a 6 inch spring lift will clear 36 in tires no brob.
71 3/4 ton 4x4,665hp 454.
67 GMC 1 ton towtruck
68 chevy LB 4x4
64 chevy LB custom
57 Bel-air 2d station wagon
mikep684x4 is offline   Reply With Quote
Old 11-29-2003, 05:09 PM   #5
SEVEND2
SEVEND2's Avatar
http://www.teamzebra.homestead.com/Truck_Specs.html
On a 76 frame
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 11-29-2003, 09:43 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
hey mudder lol hold them thoughts im thinking it may be my next project!! lol
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
