Old 07-02-2013, 07:30 PM   #1
brisonac
muffler question
just put my exhaust on my 402, 2 1/4 inch piped dueled with flowmaster 40's (my dad bought them without me knowing)
they exit right in front of the rear tire but they had to put the muffler real far back. but my problem is that it is really quiet, but my dad said that was because it was so far back. is that true? if so what other muffler would you get to have a deep loud rumble sound?
also its running close to 400 hp and 10:1 compression if that helps
My Fleet:
1968 Mustang,1972 C10, 2002 Lincoln LS
Father and grandfater restored Fleet:
1957 Bel Air 2door convertable, (in progress)
1957 4 door post, (in progress)
1959 Star Chief, 1966 Impala, and many others
brisonac is offline   Reply With Quote
Old 07-02-2013, 09:01 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: muffler question
I have some expereince working at a muffler shop about 25 years ago and I do not or will I ever believe that muffler position has anything to do with noise level. Does your truck have headers or exhaust maniflods? Typically headers produce a little more noise. What configuration is your truck? Is is long bed 2 wd / short bed 4wd, etc?
The mufflers really only fit good in the factory position which is just behind the cab. My advise would have been to use 2 1/2 inch pipe and point the tail pipes toward the ground for some extra noise. If that is not enough, you can just run a straight pipe were the mufflers were, that will get a lot of attention and make a lot of noise too.
TBONE1964 is offline   Reply With Quote
Old 07-02-2013, 09:39 PM   #3
brisonac
Headers, an long 2wd. And the muffler is just past the cab under te bed
My Fleet:
Old 07-03-2013, 12:35 AM   #4
Square_78
Square_78's Avatar
I have headers in mine with flow master 40's in a true dual setup and its LOUD. I need ear plugs on the highway. 94db inside the cab with the windows up. I can't imagine anyone wanting their exhaust louder than that. If your exhaust is too quiet then change the mufflers or use resonators instead of mufflers. Shouldnt be hard to get a small block Chevy to blast your ear drums if you want it to.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 07-03-2013, 03:39 AM   #5
BlackedOut67shorty
BlackedOut67shorty's Avatar
Glasspacks out the sides..that should get some attention
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 07-03-2013, 04:55 PM   #6
AirSpeed
AirSpeed's Avatar
I have a pair of 40s in my shortbed, they're almost to the rear axle and they are loud. Are you sure yours are 40s? I can't see your pipes to the muffs being to much further back than mine are, specially if they exit in front of your tires, mine exit behind. I have stainless tips on mine, they're 3" in diameter and I think they make it a little louder.
AirSpeed is offline   Reply With Quote
Old 07-03-2013, 05:05 PM   #7
volksworld
I think your dad bought something quiet to keep you out of trouble and TOLD you they were 40s
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-03-2013, 06:19 PM   #8
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Mine: 2WD Blazer with 2004 5.3 with factory exhaust manifolds- 40 Flowmaster with 2 1/2" Head pipes and 2 1/4" Tailpipes. Mufflers in the correct location. Sounds great and not too loud and no resonance. Tailpipes are out under rear bumper. I'm not running the top on the Blazer, that may make a difference, but Im not planning on runnin' with a roof
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-03-2013, 06:28 PM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Ive never heard a quiet 40, I think he's pulling your leg
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-03-2013, 07:09 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yeah but glasspacks sound like crap!
I agree... I have 40's on my '72 GMC and it is a loud mo-fo. Loud enough to set car alarms off in parking lots. I have a lot of buds that are running 40's as well... they are not quiet.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-03-2013, 08:14 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
I had FM 40's dumping at axle on my 79 malibu w/383 and it was too loud. I have never heard complaint that 40's were too quiet. The 383 recently self destructed and i installed a milder 355.. I am also swapping the 40's for Sonic Turbos and tail pipes.
WIDESIDE72 is offline   Reply With Quote
Old 07-03-2013, 10:37 PM   #12
BlackedOut67shorty
[QUOTE=GASoline71;6155477]Yeah but glasspacks sound like crap! :lol
Yeah lol they do, especially going down the highway at 65, been trying to find a Lil more mellow exhaust. When I was first driving I wanted it stupid loud, have it like that when you start driving and it got old fairly quick
Posted via badass Mobile Device
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 07-03-2013, 10:47 PM   #13
jhwkns
Registered Cruiser
jhwkns's Avatar
I've got the biggest quietest mufflers I could find. 2.5 in 2.5 out. Free flowing, and I can talk to my passenger on the highway without shouting. Your Dad is wise. The noise gets old real quick. Put some cutouts on it, and you can be real loud when you wish.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-04-2013, 12:06 AM   #14
GASoline71
GASoline71's Avatar
What fun is that?
Gary
Old 07-05-2013, 12:56 PM   #15
brisonac
That's pretty weird. Would the exit points of the exhaust make a difference? I was thi king cut outs to, just so I can be as on obnoxious as I want. This isn't a daily driver either, just for fun and for car shows
My Fleet:
Old 07-05-2013, 02:05 PM   #16
BlackedOut67shorty
Yes it would
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 07-05-2013, 07:45 PM   #17
weever82
weever82's Avatar
Get underneath the truck and look at the numbers on the muffler and check it out online. It will tell you if they are 40's or maybe something quieter like 50's...
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 07-05-2013, 09:51 PM   #18
GASoline71
GASoline71's Avatar
My exhaust is 3" and dumps out in front of the rear tires at an angle.
Gary
Old 07-06-2013, 06:44 AM   #19
elf w/capital T
Really you guys think that fm40s are loud?? Well what muffler n setup did you go with? I had some imitators of the 40s the previous owner put on, i liked and thought they were fm40s... but i WAS going to get them, but ya guys are saying they are loud.....
elf w/capital T is offline   Reply With Quote
Old 07-06-2013, 10:07 AM   #20
ironroad9c1
Master Hater
well first off flows are the worst flowing muffer out there next to stock, second 2 1/4 pipe is too small for any performance small block, you need tom dynomax ultraflows, hooker areo chamber, or magnaflows , hell even the cheapo summit turbo mufflers outflow flow crappers.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 07-06-2013, 05:47 PM   #21
Square_78
Square_78's Avatar
Gary
I agree. Mine sets off car alarms when I just idle through a parking lot with my foot off the gas.
#teamlongbed
Old 07-06-2013, 11:35 PM   #22
Toxic Orange
Toxic Orange's Avatar
I've got 40's that sit just about under my seat, headers and 2 1/2 inch pipe. Exit is out the side in front of the rear tire. 3" resonating tips and they are loud but meaty, just like I wanted. Most would think (and be right) that they were too loud if a daily driver, but for a weekend driver they work great. Does yours have any type of chrome tips? That seems to make a big difference.
Toxic Orange is offline   Reply With Quote
Old 07-07-2013, 07:45 AM   #23
elf w/capital T
Toxic, those look pretty nice!
How about these chambered mufflers jegs brand... anyone?
http://www.jegs.com/p/JEGS-Performan...25416/10002/-1
Old 07-07-2013, 07:48 AM   #24
elf w/capital T
Brisonac, sorry didnt mean to jack your thread! Mods can delete post!
Old 07-07-2013, 10:19 PM   #25
brisonac
Wait up. It's a 402 bb. And 2 1/2 in exhaust. Sorry bout saying 2 1/4
My Fleet:
