07-10-2013, 06:46 PM | #1 |
Service engine soon light
To explain, all the vacuum lines on my electric quadrajet had no hoses. As I tried to figure which ones needed to be plugged and connected, I had put my finger over the manifold pressure tee a couple of times and I assume this is what gave me the service engine soon light. Strange thing though after I got the vacuum lines plugged and the distributor vacuum advance hooked up, I still had the engine light on and my voltmeter was pegged left about 9 oclock and oil pressure pegged past 60. Any help as to what could be the cause would be nice. Still trying to find the ALDL switch to see if I can figure out what the code is, but the gages are really throwing me for a loop. Truck runs fine, use it as a daily driver and have had no issues driving with the service engine light on.
07-10-2013, 07:04 PM | #2 |
Re: Service engine soon light
If it annoys you, take out the bulb and send me the lens I need it LOL
07-10-2013, 07:37 PM | #3 |
What year, you need to check the codes.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
07-10-2013, 07:48 PM | #4 |
It's an 1985, 305. I would love to check the code but I just spent the better part of 30 minutes looking all under and around the dash and found nothing that looks like the aldl port out of the Haynes manual
07-10-2013, 09:21 PM | #5 |
I think you have obd1..you can check it with a paperclip...try this. It's probably the best explanation I have found
http://www.theimportkiller.com/forum...hp?topic=420.0
07-10-2013, 09:28 PM | #6 |
I think I am just going to take a hammer to it until the light goes away, looked everywhere and can't find the connector. Really just want to know why my gages are pegged out.
07-10-2013, 09:48 PM | #7 | |
We have all been there...
07-10-2013, 10:00 PM | #8 |
Moderator
Which gauges are pegged?
The ALDL port should be somewhere near the steering column under the edge of the dash sheet metal.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-10-2013, 10:06 PM | #9 |
The voltmeter is at 9 o'clock oil gage about 2 o'clock the coolant temp is reading high, close to the red after warming up and I filled up about three days ago and the fuel gage is still reading full. I know vacuum advance is supposed to help fuel economy but I doubt it would make that big a change
Posted via Mobile Device |
07-10-2013, 10:31 PM | #10 |
I'm not sure about the Voltage gauge being spiked but on my 85 if the Oil pressure sending unit wire comes un plugged it pegs at the top of the gauge, maybe you unhooked something with out realizing it.
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world! |
07-11-2013, 01:54 PM | #11 |
so I'm pretty sure I have a ground somewhere, filled up today and the gas gage went to the 4 o'clock position. Now I just need to figure out how to trace down the ground
07-11-2013, 03:13 PM | #12 |
Junior Member
Disconnect the battery for about an hour and see what happens when you hook the battery back up and starts the engine.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-12-2013, 10:06 AM | #13 |
Moderator
Your gauges are analog meters. The ECU is for spark knock control and maybe some coarse fuel mixture control it doesn't run the gauges.
Volt gauge at 9:00 0VDC = No power or no Ground at the cluster plug damaged flexible printed circuit or a bad volt gauge. Oil gauge at 2:00 (pegged) usually means you've inadvertently unplugged the sender wire, the wire is cut, or the sender has failed. If you ground the oil pressure sender wire it should read 0 PSI. Temp gauge sounds like it's got a failing sender or the wrong sender was installed sometime in the last 28 years. If the temp sender wire is partially grounding on the exhaust manifold or somewhere else you could get a nailed temp gauge too. Assuming that the fuel gauge does move and eventually reads E when you're close to empty... The fuel gauge sender is engineered to read near full for almost 3/8 of a tank... GM did this with all their cars and trucks after early 1974. I have the '70s Chevrolet Service News with an article that outlines this change. This is why a "normal gauge" reads close to full for quite a while and then drops relatively fast after it starts to move. All of the "Big 3" did this.
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-12-2013 at 10:12 AM. |
