#126 |
Re: 89 crew cab k20 4wd twin turbo cummins swap
looks good, as long as it works that's all that matters in these old trucks.
#127 |
Dropped the cab on the other night.. but had to pull it back off right away... While i was rolling the frame it didn't feel right, something was binding, that's when i discovered the CV joint on the front driveshaft was bottoming out. So now i have to install a clocking plate from offroad design to lessen the angle of the driveshaft. Plate should be here in a few days then hopefully the cab and box can go on for the FINAL time. Here's some pics before i pulled the cab back off.
#128 |
6>8 Plugless........
![]() Join Date: Sep 2007
Lookin sharp!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#129 |
#130 |
nice pics!
congratulations...lucky guy!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#131 |
Congrats on your wedding!
#132 |
Thanks guys, happiest day of my life
#133 |
I'm glad to see you had good weather! My wife wanted an outdoor wedding. I knew what kind of luck I had and opted for an indoor.
#134 |
Congrats Mr Miller.... Honeymoon's over now get that truck finished
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#135 |
#136 |
those gauges..... can you get a pic up of what it looks like from the driver seat. i have been looking for a way to monitor my motor but cant really find anything that i like the way it looks, and i want to run more then 4 gauges. last long bed i built i ran the gauges in the cowl of my 4in cowl hood and it turned out amazing but now i want to keep everything inside
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers 1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles "Life is full of decisions, we make them and dont look back" |
#137 |
Yea, i've been waiting to let this little secret of mine out til i had it finished. I bought the gauge pod for like 12 bucks off ebay, heated and molded it to the dash, then drilled and welded nuts on the inside of the dash pad so i can easily pop it off if i need to. Looks absolutely great from every angle, I love it! Yea i had the same problem, i needed more gauges but didn't have a good way to mount them without looking cobbled and unprofessional.
#138 |
#139 |
I like the way you mounted the pods on the dashboard. custom? or did you just use and bent a original part?
#140 |
awesome! i might have to steal your idea
#141 |
Sweet truck. Can you tell me/us more about your tow mirror set up? Looks clean.
Posted via Mobile Device |
#142 |
The gauge pod is 25 bucks on ebay. Made of abs plastic so it's really easy to heat up with a heat gun and form it to the dash. looks and fits very well in my opinion.
I tried a few different ways with the mirrors but this was the best. I welded in a heavy plate for the mirror to bolt to so they wouldn't wiggle while driving and look blurry. Drives me nuts when I can't see clearly out of a mirror.. Heres a couple more pics I took for ya ![]() ![]() |
#143 |
#144 |
#145 |
#146 |
#147 |
Man you've done an awesome job.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
#148 |
Just an idea For the custom ax lines.. Go to your local case ih or Deere dealership. My buddy works for Case and plans to build the lines for our Cummins Chevy k20 build. He has all the lines there.
Zaccaglin 1998 Chevrolet C1500 Ext. Cab 350 Former Rig: 1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208 |
#149 |
Thanks I will.
Some pics of the offbrand Dynamat. Installed 70 lbs worth in just the firewall and floor. I did 2 layers on the firewall to make sure no noise makes it through! ![]() ![]() ![]() ![]() ![]() ![]() ![]() And the doors will get covered once they are finished. I also filled the roof of the cab with liquid foam to block out more noise. |
#150 |
This is one of the best truck builds I've ever seen. Awesome job! It is really coming together now. What did you use for the roof foam and how did you apply it?
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 ![]() |
Tags |
4wd, c/k 30, crew cab, cummins swap, twin turbo |
